It is currently Sat Nov 21, 2026 8:54 am
 Posted: Thu Dec 09, 2004 11:20 pm |
Hello all... Sad sad day in my life today. As I was changing songs, and looking down, this big crew cab GMC is turning left. I slammed on the brakes and it wasnt good enough. Those bastards left thier hitch receiver in, and totally, royally, thouroughly F*&KED my front end. I'm not saying its thier fault I decided to ram the receiver, but still. No damage AT ALL to them.
WE CAN REBUILD HER.... BETTER THAN BEFORE...
Hopefully it doesnt cost me six million dollars. I am doing it myself. Yes. All by my lonesome, just to see what kind of job an amateur can do. And we'll have to wait for the end of the project to grade my performance.
I need a new bumper, new grilles, fascia, right side fender (from a previous event), two new headlights (AGAIN!!!), new rad mounts (thank god the rad is fine), and whatever else I discover along the way.
I am looking into the possibility of just purchasing a whole front header from the wreckers. If that is the case, does anyone here know if the buick T-Type front header will just bolt on in place of mine?? From all the pictures I can find of those cars, the fenders, and everything looks like it all ends up in the same place. Possibly the reverse opening hood would screw me up though.
And from what I can see, I must commend the good people at oldsmobile for designing a car that is so forgiving... Most everything damaged here is built so it can be unbolted, and a new one bolted in place! Simple as finding the right parts to bolt!... Then I'll fill all my door dings, strip the trim down and paint. It'll be an educational experience.
Ill put up pics of the car tomorrow... Its a sad lookin sight.
Hans
 Posted: Fri Dec 10, 2004 4:31 am |
88delta88 wrote: Hello all... Sad sad day in my life today. As I was changing songs, and looking down, this big crew cab GMC is turning left. I slammed on the brakes and it wasnt good enough. Those bastards left thier hitch receiver in, and totally, royally, thouroughly F*&KED my front end. I'm not saying its thier fault I decided to ram the receiver, but still. No damage AT ALL to them.
really sorry to hear that.
I did the same thing when I had my 87, the headlights were quite expensive from the dealer as the junk yards did not have them.
good luck.
OldsGuy
 Posted: Fri Dec 10, 2004 7:21 am |
Sorry about the bad luck. When you get the bad parts off, look real close for radiator support damage or frame damage on the front. They could be bent ever so slightly which could cause alignment problems when the new parts are installed. Good luck.
BTW, I am with 100% of the votes for painting the same color, wait, I am the only one to vote so far  ops: , 1 of 1 is 100%, oh well. I say the same color because it will be easier, cost less and you wont have to worry about painting door jambs, under the hood, etc...
No53Alero
 Posted: Fri Dec 10, 2004 8:39 am |
Joined: Mon Jun 09, 2003 10:30 pm Posts: 156 Images: 42 Location: CINCINNATI, OH
sorry to hear about the accident. I did that in my lowrider when I just got it except it involved rain, a sharp bend, too much speed, and endedd w/ me ramming a guard rail with my front then back quarter panel. It didn't stay wrecked for long though, about one day total. Had to get new header panel, 1 corner marker, and new driver's fender, and get back quarter panel pulled out. My car was mint before that, only had 82k miles! But I would check the frame and all as ever since then I've had a slight vibration when cruisin down the highway. Good Luck though, it's no too hard to do.
_________________ One and Only Airbagged ciera!!
Final 500 Alero website
 Posted: Fri Dec 10, 2004 9:46 am |
I had an old body guy at work look it over, and he said its fixable. He said if I'd have taken the hit without absorbing the hitch receiver, it would have meant a LOT more damage...
 Posted: Fri Dec 10, 2004 3:49 pm |
damn kids and their stereos!
Should be a good learning experience fixing her up...
BigBlockOlds
 Posted: Fri Dec 10, 2004 9:22 pm |
88delta88 wrote: I had an old body guy at work look it over, and he said its fixable.
Anything can be fixed with enough money. Afterall, these cars were made by men, not God.
468/T-56/3.73
 Posted: Fri Dec 10, 2004 9:56 pm |
Thanks for all the support, guys, makes me want to fix her even more!!!
I got some of the parts I know I'll need from the wreckers. I found these items:
(canadian funds)
Bumper -$200
bare hadlight mounting header - $150
left hand grille -$50
Thank god I knew someone at the yard, and they sweet-talked and got it ALL for $150.00 even. Thats a deal and 1/2.
I need right hand grille, and at least one new headlight aswell. These items I couldnt get at the wreckers in town here. I'm debating whether or not to try and do body work on my hood and right hand fender, or buy new ones. I'm leaning towards the new ones. I will need a rad support aswell, but have to find all these items first. Anyone parting out????
 Posted: Thu Dec 16, 2004 1:57 pm |
Ok... So, here are the first pictures of what I have to work with.
Pretty nasty, but at least I didnt damage the hood too badly.
I just came across an AWESOME deal today, someone is getting rid of thier 87 delta 88 with a dead motor for $40.00 canadian!!! He just wanted it gone. All the front end is there. How much better of a deal can one ask for??? Too bad I already forked out 150 bux for the bumper and front header...
 Posted: Sun Dec 19, 2004 10:25 pm |
So, how's it coming along 88delta88?
Taking a second hand look, I'd have to agree...that trailer hitch saved your car from being completely totaled. At least you're okay.
Cars can be fixed...people aren't as easy to rebuild...
 Posted: Mon Dec 20, 2004 10:20 am |
Ok, worked my ass off this weekend, and I got a LOT done. I will post a few pictures when it gets light enough to take some outside. I need to do some adjusting, to get my lines back, but other than that and some paint, she looks good! A lot better than she did look anyways. It was fun trying to figure out how to bend all the brackets and crossmembers back to normal!
GREAT learning experience, DEFINATELY recommend it to anyone in my predicament!
 Posted: Mon Dec 20, 2004 11:56 am |
OK... Pics up! Have a look and tell me what you think of my repair job so far... Keep in mind that nothing is lined up yet, I just fitted everything for reference.
I still need 2 new headlights, and a right-hand grille. No biggie. Still waiting to get my hands on that parts car!
Brando - I couldnt fit anymore pictures in my album! I cant find out how to delete some of the older pics I no longer want... Thats the only reason I used the newbie album.
 Posted: Mon Dec 20, 2004 12:11 pm |
88delta88 wrote: Brando - I couldnt fit anymore pictures in my album! I cant find out how to delete some of the older pics I no longer want... Thats the only reason I used the newbie album.
Tell me what ones you want deleted.
It's looking pretty good so far.
 Posted: Tue Dec 21, 2004 10:09 am |
I didnt realise till now that I have clear cornering lenses!!!  whoopie!
