It is currently Sat Nov 14, 2026 7:35 am
 Page 1 of 1 [ 8 posts ]
PostPosted: Wed Dec 24, 2003 12:44 am
TOC Village Ricer
TOC Village Ricer
Images: 20
do u know if the chevy camaro rims from 82 to 92 will fit my 88 cutlass cirea since they r both 5 lug
i havebeen askin a lot of ppl but thet don t kno so do u kno
im gonna :blowup: if i dont find out
well maybe not that far lol but plz if u kno hit me back on dis plz thanks]
oldsmobile420
PostPosted: Wed Dec 24, 2003 3:58 am
No, they will not fit unless you use an adapter...they are a 5 lug hub, but use a different diameter bolt pattern
PostPosted: Wed Dec 24, 2003 4:07 am
TOC Village Ricer
TOC Village Ricer
Images: 20
where can i get a adapter at for then cuz i have a friend that is gonna sell then to me 4 of them and i can get them for 100 a i really want them i think they would look good onmy car
also do u kno any good oldsmobile websites for part s for my cutlass cirea
PostPosted: Wed Dec 24, 2003 10:02 am
Measure the bolt pattern...
Machismo... That tire size calculator site you referred us to, I beleive that also has instructions for measureing bolt patterns. Would you be kind enough to refresh our memory on what the link is?
I would think though, that those camaro rims are 5 on 4.5... Or 5 or 4.75...
Thats the experience I've had with chevy bolt patterns.
My olds' rims are 5 on 4.5.
PostPosted: Wed Dec 24, 2003 10:04 am
Oh... one thing...
I hope you arent planning to lower your ride with those IROC rims on there...
They're RWD rims, so they're going to stick WAY out past your fender wells. It'll look sweet, but big bumps might send your tire straight into your fender, may cause some damage...
Airbaggedcierra, do you have problems with your wheels hitting your fenders?
PostPosted: Wed Dec 24, 2003 10:10 am
Good deal for 100 bux, but you will have more headache it sounds like that its worth...
Find some 97 or so cavalier 5 spoke wheels... Same idea, but they're made for FWD and they'd likely fit a bit closer.
PostPosted: Wed Dec 24, 2003 3:15 pm
Images: 42
With the 13x7 reverse and std offset wire wheels my fender lips will sit directly on top of the tires. it doesn't hurt the fenders surprisingly, but cuts tires pretty good when they hit, won't pop them but it cuts the tread up. he really shouldn't have a problem w/ that unless his fenders will be sitting 1.5-2" or less from the tires. Also it isn't to smart to but a bigger rim 16" on up RWD rim on a FWD car.
Final 500 Alero website
PostPosted: Wed Dec 24, 2003 4:20 pm
FWD GM's bolt pattern is metric, 5 X 115mm your RWD rims are 5 X 4 3/4. i really don't think they work at all, the adaptor is going to be around an inch thick, so the wheels will be way out passed the fenders.
