It is currently Sat Nov 14, 2026 7:07 am
 Post subject: can u guys tell me
PostPosted: Wed Dec 24, 2003 4:59 am
TOC Village Ricer
TOC Village Ricer
Images: 20
what rims would look right on my oldsmobile cutlass cirea
thats my page so if u would plz go there and post here and tell me thanxs
http://www.cardomain.com/id/blingbling666
oldsmobile420
PostPosted: Thu Jan 15, 2004 6:56 pm
I think the rim in the upper right corner (without a tire, silver colored) is the best 1
PostPosted: Thu Jan 15, 2004 7:11 pm
the three camaro wheels will not fit on your car unless you use a wheel adapter/spacer. Those are for a RWD car, and have a different bolt pattern as well as a different offset. RWD GM midsize cars use a 5 bolt 4 3/4" bolt pattern, and yours is either a 5 bolt 115 mm pattern, or a 5 bolt 110 mm pattern. You will most likely be looking at a fairly thick spacer, which may have to be custom made, costing a few $$$$, plus finding a tire that will fit well may also be a hassle. The 2 top wheels are 16x8...the left off a early 90's camaro RS, the right off an IROC...the red wheel came on most camaros from the early 80's up till the body change in 91...those are a 15x7 or 8 wheel.....you may be better off finding an aftermarket wheel that you like, as you'll spend some fairly good $$$ buying adapters that will correctly fit these to your car...just my .02 cents...
