It is currently Mon Jul 27, 2026 5:30 am
 Posted: Sun Jan 28, 2007 10:13 am |
I would suggest a proper application of contact cement. I have used clear silicone in the past with emblems and badges with good success, but I am afraid the moldings are too heavy for mere silicone.
 Posted: Mon Jan 29, 2007 10:00 am |
Contact cement is great stuff, but, PVC cement, as you suggested earlier, would have a different outcome.
bdyman
 Posted: Mon Feb 05, 2007 12:42 am |
Joined: Wed May 19, 2004 2:16 pm Posts: 171 Images: 22 Location: chicago baby!!!!
correct
remove any old glue or tape from the car, i use a earser wheel you can buy them at body shop supplier, no good method of removing old tape off body side moldings i use a razor blade and peel off the old tape
make sur eyou clean the molding off real good using laquer thinner of a wax and grease remover
reapply the tape re apply the molding
i suggest not doing a glue on moldings to big and to heavy again 3m makes a name plate glue just for name plates only
_________________ how low can you go????........pssssssssttttttttt.....got air???
bdyman
 Posted: Fri Feb 09, 2007 7:37 am |
go to your local body shop supplier store they will have it
just ask for double sided tape
