Does anybody know a good and cheap place to buy replacement fenders? I need a front passenger side fender because the one I have has a hole in it. Thanks for the help in advance.
Check your local junk yard, the full size GM cars with the plastic fenders are known for having this problem. I have a small hole in the fender of my 93 LeSabre and had to replace the fender on my old 92 Bonneville. They arnt hard to remove and should be in supply in the scrap yard.
_________________ .
You oughta go to the junkyard with some tools, you'll be amazed! They got more stuff then you think. Last summer when I went hunting for a bumper, I found a burned cat underneath the car.
I will try that. There aren't too many junk yards around here, but there are some a short distance away. I guess I will have to make a trip there this weekend. Thanks for the advice.
Users browsing this forum: No registered users and 1 guest
