It is currently Mon Mar 16, 2026 1:07 am
 Posted: Fri Jul 06, 2007 5:47 pm |
You can buy *legal* bulbs from your local auto store, they are called "Silver Stars" by Sylvania. They are quite good from the reviews I've heard, but dont give you the blueish tint that the real HID headlights give off.
You can also buy *illegally* colored bulbs off the internet, and give off a distinct blue tinge to the lights. They look really nice. Drawbacks include headlamp cover melting (most are higher wattage to overcome the colored coating), and getting pulled over and frivolous ticketing by law enforcement.
 Posted: Sat Jul 07, 2007 5:53 pm |
I think the silverstars look great on any car. I hate the yellowish glow of standard halogen. I have a set of the illegally colored lights on my car, I bought off the net, and I love the way they look. But I also know that the cops dont like them around here. I take my chances for the good looks
 Posted: Tue Aug 07, 2007 5:03 pm |
The dial things you speak of are likely just that - turn counter clockwise, and it should click and let go of the light. I am sure you are aware about not touching bulb glass, or it will fail prematurely.
raskull
 Posted: Wed Aug 08, 2007 10:26 am |
Joined: Thu Jul 05, 2007 11:46 pm Posts: 106 Location: Worcester, MA
So yeah i went out and tried to unscrew those plastic things again. I tried spraying some wd40 on it. The problem is there so tight that i couldn't even spray anything of importance. It worked a little and one of them moved about 1/4 inch. I dont want to strip them because they are made of plastic.
My net progress = i cracked the silver plastic trim of the right turn signal and now it's missing a piece.
I dont understand why this is so difficult lol
 Posted: Wed Aug 08, 2007 11:07 am |
I just re-read the first post... Are you working on the TOP of the light fixture, or behind the light, in the engine compartment?
The bulbs are inserted from the rear of the light fixture, and held there by a plastic ring that basically snaps down to the fixture. The ring is loosened by turning it counter clock wise with your fingers, then the whole bulb/ring/wire assy will pull out the back of the light.
In most cases, the light fixture does not have to be removed, but, to do the passenger side light in my car, I have to remove the coolant overflow tank, to get my hand down in there. Excessive force on the ring shouldnt be nessesary, but you may have to press gently while turning it.
