It is currently Sat Oct 31, 2026 7:22 am
PostPosted: Mon Dec 15, 2008 2:43 pm
I have a 95 cutlass ciera and I would like to remove the door moulding. how would I best go about this it looks like it's just glued/tacked on but are there any hidden screws or clips I need to worry about?
PostPosted: Wed Dec 17, 2008 11:56 am
I think that year uses plastic clips behind the trim. I'm not sure if they had any screws.
PostPosted: Wed Dec 17, 2008 3:28 pm
If there are any screws, they'll likely be at the ends, but I don't think it's screwed on.
Best way to take that off is with a putty knife and a heat gun/blow drier. The rubber will be more pliable, and the glue less stiff- less chance of taking off paint that way. You probably can get it hot enough to bubble paint though, so be attentive while using the heat.
PostPosted: Wed Dec 17, 2008 8:20 pm
Yeah thats how I was gonna do it if it didn't have screws/clips. I'll probably dive into it after it gets a bit warmer. thanks for the info
