It is currently Thu Nov 12, 2026 1:08 am
 Posted: Wed Apr 21, 2004 8:08 pm |
73Delta88 wrote: try some fine grade sandpaper on the rough spots then do the whole wheel with some good cleaner wax.
Hi furyolds, Hi all
Makes sense to me. Why pay someone else to do what you can do yourself. Painted aluminum would best be reserved for a sleeper.
But if you still want to go with black, change 73Delta88s recipe to use semi-gloss spray cans instead of polish.
strokercutlass
 Posted: Wed Apr 21, 2004 9:56 pm |
| TOC Mechanic |
I've done this in the past with several sets of factory aluminum wheels...while its kinda a pain in the ass, they look nice when done...I've stripped the factory clearcoat using aircraft stripper, then did as 73delta said and used sandpaper (starting out with a somewhat fine grade and getting more fine as I went), then polished the wheels using Mothers mag and aluminum polish, and if I felt like it, recleared them....is it time consuming? Yes....BUT, you can say you did it yourself, and think of it as a learning experience...just my .02 cents
 Posted: Thu Apr 22, 2004 8:31 am |
my brother painted the rims on his car black, from an aluminum color... It looked horrid! The look of black steelies just couldnt be helped! I would recommend you at least dont paint them black...
 Posted: Thu Apr 22, 2004 11:05 pm |
do like they've been recommending and polish em! Those are nice rims man... And if you look in GM's catalogue, they're more like 500 bux a piece...
Its up to you though...
 Posted: Thu Apr 22, 2004 11:06 pm |
What's that "OldsConnection.com" watermark doing in the lower right corner of that picture?
I agree...polish them!
 Posted: Fri Apr 23, 2004 8:20 am |
i was just looking at your location... you're not in vernon B.C. are you? Just wondering.
 Posted: Fri Apr 23, 2004 12:14 pm |
oh well its cool to know at least ONE person is close to my area...
I'm in lethbridge...
