It is currently Tue Nov 17, 2026 1:15 am
 Page 1 of 1 [ 10 posts ]
PostPosted: Tue May 11, 2004 4:10 pm
what options are there for changing a steering wheel with an airbag?
anyone know how to take off the shift knob on an automatic gm? where/what can be used for a replacement/upgrade? (mine is pretty worn looking...)
this is the closest i could find...
Zig's
PostPosted: Mon May 17, 2004 9:50 pm
Images: 19
I have been thinking about just cutting the end off the end of my shifter and putting a custom on cause I don't see how to get it off otherwise. Damn column shifter.
1995 Olds. Cutlas Ciera - 3.1 V6
Want a Station Wagon Ciera
www.theburningcandle.net
PostPosted: Mon May 17, 2004 10:25 pm
i'd think there would be a set screw holding it on and then would screw off. but i'm sure you all already checked that,right?
could also be just glued on.
you could always take a pair of vice grips and just crush the tip of it and see how it's held on. would be better then cutting it off in my opinion.
i'd go look at mine but ofcourse i have a floor shift so cant help you there.. :lol:
wanna see :D
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
PostPosted: Mon May 17, 2004 10:52 pm
It's just plastic....the end kinda pops on...if you pull hard enough (or not much at all in my case) it will pop off... :shock:
PostPosted: Tue May 18, 2004 10:26 pm
Images: 19
i should try that
but i plained over it so i bet its gonna be a pain!
PostPosted: Tue May 18, 2004 11:52 pm
ok about the air bag. i did this to mine to put on the chain steering wheel but took it off so i could get a new one.
1. Un hook your battery to make sure.
2. Take out the air bag fuse.
3. Unbolt the air bag.
4. When you go to get a adapter for your new steering wheel tell them you have a 1988 cutlass ciera with no air bag for the adapter. for the simply fact that they don't want you to take out the air bag.
5. Bolt it all together and don't put the fuse back in and hook up your battery. I know the air bag light will stay on but i didn't put my fuse back in and the light stays on but i would be afriad to put it back in cause it might mess something up. have fun trying to get off the factory steering wheel cause mine was a bitch and a half to get off.
Rusty Froman
President and Founder of Simply Irresistible Car Club
http://sicc6.tripod.com
http://www.cardomain.com/memberpage/347561
PostPosted: Tue May 18, 2004 11:57 pm
i wonder if mine even has an airbag it doesn't say airbag anywhere.....
PostPosted: Wed May 19, 2004 12:01 am
well look through pic's and see if you have the big center peice or the one that looks like a upsidedown T if it is the big one you have a air bag and if you have the upsidedown T you don't
Rusty Froman
PostPosted: Wed May 19, 2004 1:29 pm
woah dont cut the knob off your column shift, its glued on.. i replaced mine (as well as turn cignal and tilt wheel) with chrome ones from jegs... no cutting involved
1995 Saturn SL2 (SOLD)
PostPosted: Sat Nov 05, 2005 6:25 pm
for the shifter (at least in my old 91 lumina) there is a retainer clip on the back(front of car) side.... pull it out w/ the needlenose pliers and then the knob should just pull off.
