It is currently Sat Nov 07, 2026 9:19 pm
 Posted: Fri May 14, 2004 3:58 pm |
i like the way 18"ers look on our cars. I particularily like spokers.
88Ciera_SC
 Posted: Sat May 15, 2004 5:58 pm |
nothing but 14's for me...
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
 Posted: Sun May 16, 2004 12:18 am |
justinwebb wrote: isn't that just to drop it down? cause u also have to put on a camber kit to make the wheels run true again not slanted....
I think the eibach kit is only like an inch drop if that? Maybe 1.5"?
Drop it over 2" and you'll need a camber kit, which angles your wheels/tires so the tire isn't riding on its side, which wouldn't be good...at all.
 Posted: Sun May 16, 2004 5:57 pm |
justinwebb wrote: would dropping it down 1' to 1.5' be that noticeable cause that isn't a whole lot
TALK ABOUT SLAMMED! 1 ft to 1.5 ft....that's a whole lot....
Definately would be noticeable....(Talking about 1" to 1.5")
 Posted: Sun May 16, 2004 11:47 pm |
i dropped my car 2.5" and I need a camber kit on the rear end. the front end adjusted very well. Its not a REAL big problem but you can see a slight angle when you look really close.
