It is currently Mon Nov 09, 2026 9:41 pm
 Page 1 of 1 [ 9 posts ]
 Post subject: Hello
PostPosted: Fri Dec 16, 2005 12:28 am
Hi everyone,
My name is Freeman Sawyer and I race my 86 Olds Cutlass Sumpreme at Airborne International Speedway. It's a semi banked asphalt 1/2 mile. Hope you all can help me on some questions cuz this car is new to me. Thanks
 Post subject: Re: Hello
PostPosted: Fri Dec 16, 2005 1:35 am
Hi Renegade # 51, Hello everyone,
........ Hope you all can help me on some questions ........
I don't know that there are any roundy racers on this board.
Your sig shows a 305 engine, which is a Chev. Chev site would be populated by people more likely to give you correct answers.
I've had more than a little experience with Ford, Mopar, and GM, but I only talk Olds on this board.
PostPosted: Fri Dec 16, 2005 1:49 am
Olds also used the 305, I'd like to know if they used it with center bolt heads in the Cutless Supreme between 81 and 86.
Last edited by Renegade # 51 on Sat Dec 17, 2005 10:45 am, edited 1 time in total.
PostPosted: Fri Dec 16, 2005 3:20 am
Renegade # 51 wrote:
Olds also used the 305 ........
I am well aware of that fact, and just as aware that the 305 is a Chev.
Are you aware that the 307 Olds and 305 Chev engines are two different designs and that nothing interchanges, except the distributor cap and rotor?
I'd like to know if they used it with Vortec heads in the Cutless Supreme between 81 and 86.
Your machine shop should have the answer.
PostPosted: Fri Dec 16, 2005 8:32 am
Yes I am, and like I said i've made the calls and did not get any results on this end. I guess what I am asking is, did Olds ever put a 305 in there Cutless Supreme ?
PostPosted: Fri Dec 16, 2005 5:19 pm
Hello and Welcome to the site.
I believe Oldsmobile putting Chevy 305s stock in the Cutlass was a Canadian thing.
PostPosted: Fri Dec 16, 2005 7:48 pm
........ I'd like to know if they used it with Vortec heads in the Cutless Supreme between 81 and 86.
Checked with my shop. They knew the answer. It's why I use them, and it's why I'm answering your Chev question here:
First Vortex heads appeared in '95. You probably have them confused with a similar combustion chamber design that was used in '87. It was designed for, and used with, the TBI, to meet emissions requirements.
PostPosted: Sat Dec 17, 2005 10:44 am
Thanks for your help 88 Coupe and Brando. Also I had a machine shop in NC call me back today and the Olds 305 center bolt heads were used on the 86.87 and 88 rear wheel drive Cutlass.
P.S. Sorry to 88 Coupe for the confusion.
PostPosted: Sat Dec 17, 2005 4:05 pm
Good luck with the tech commitee. :lol:
