Hi Randy_G, all,
What is the purpose of using colored fonts? Why do you underline words that are not links?
........ The car in the photo is a 1954 F-88 Oldsmobile ........
As far as I know, only one existed. It is in a Museum in Colorado. Check
here for Barrett-Jacksons version of it's history, and
here for it's present home.
........ I termed it a "mystery motor" simply because I haven't reseached what motor was actually put into the concept car by Oldsmobile ........
Not a mystery. Conventional wisdom says it's a '54 Olds/Hydramatic. It was a design exercise, and the mechanicals (when used) would have been "off the shelf" same as was done with the Corvette.
........ something about it auctioning off at around a million dollars ........
3 million. Type F88 into the TOC search engine.
........ Do you have resources that you consider more reliable and might recommend
Other than my memory? Not many.
For Olds, you could start
here. Helen Early's book would be good. There are two other books I can't name at the moment. All three should be available at:
GM Heritage Ctr
6400 Center Dr.
Sterling Heights Mi. 48312-2609
telephone: 586-276-0695
