It is currently Wed Nov 11, 2026 11:13 pm
lumpy
 Posted: Sat Jun 16, 2007 12:40 pm |
Lumpy here. Stumbled across your fine site while searching for tips on installing front coil springs on my '68 Cutlass S which I have been the proud (third) owner of since 1990.
I bought the Cutlass from a doctor for $2000. The car had 37,000 miles at the time. I've put close to 28,000 on since then.
My Cutlass is a 350 cid, automatic (Powerglide), non-post hardtop with ps and pb in Scarlet Red and black interior. It also had an under the dash a/c unit which I have removed. The only modifications I have made over the years is a new sound system and Super Stock II wheels.
The car is currently undergoing a sympathetic restoration; motor/trans rebuild, exhaust replacement, suspension rebuild (including those stubborn front coil springs), and fresh paint/ interior. I am also swapping the 2-bbl for a 4 and I removed the vinyl top.
When finished I will continue to drive her every chance I get, weather permitting. I'm not going for concours here, just a refresh on what was already a really nice driver.
I will post some pics as soon as possible and hit up some of the forum's experts on replacing those coil springs.
Lump
 Posted: Sat Jun 16, 2007 11:07 pm |
Hi lumpy,
Quote: ........ (Powerglide) ........ It's a common misconception. Although they are both two speeds and used the same gear ratios, your (Buick/Olds) ST 300 and a (Chev) PG are two different designs. The ST 300 used a converter that could be "switched" from a low to a high stall, in first gear, creating a "quasi" three speed trans. Quote: ........ non-post hardtop ........ Hardtop is short for Hardtop Convertible. Since neither the Hardtop or Convertible had posts, the phrase is redundant. If your VIN # begins with 336879, yours would be a "Holiday Coupe". Quote: ........ and hit up some of the forum's experts on replacing those coil springs.
We look forward to seeing your new thread.
 Posted: Tue Jun 19, 2007 1:58 am |
lumpy wrote: ........ ST 300 ........ Super Turbine 300, in case you feel the need to impress someone. I'm happy with the one in my '65. Quote: ........ tranny .........
I don't do Trannys.
 Posted: Thu Jun 21, 2007 9:28 pm |
I get your point with the whole Tranny bit... but, your linked definition also defines as:
3. tranny
In mechanics, a vehicle's transmission.
 Posted: Thu Jun 21, 2007 9:32 pm |
Good observation, M-W lists it as a shortening & alteration of the original word...Transmission.
http://m-w.com/dictionary/tranny
Regardless, welcome to the site lumpy!
 Posted: Fri Jun 22, 2007 12:09 am |
88delta88 wrote: ........ but, your linked definition also defines ........ Yes, after 1 & 2. Last time I posted the same link, It was 8 or 9, but no one noticed. Brando wrote: ........ M-W lists it as a shortening & alteration of ........
A recent addition. It shows how quickly the language is evolving.
Originally used as part of the phrase "tranny-slam", which has been called "neutral drop" elsewhere on TOC. Members of the culture who actually practiced that art, coined the word because "trans-slam" didn't sound cool enough.
For that reason, it's one of a few words/phrases that still rub me the wrong way.
lumpy: Since you do know how to spell Cutlass, you're OK.
OldsGuy
 Posted: Fri Jun 22, 2007 9:25 am |
Hi to another Missouri Olds enthusiast.
I dislike shortened phrases like "tranny" and "Cutty".
To me a tranny is a person you might find in San Fransisco, and Cutty is the first part of the word CuttySark which I think is some kind of whiskey.
I still remember when Norm corrected me on the usage of "Tudor". I am forever indebted to you Norm.......
 Posted: Fri Jun 22, 2007 6:09 pm |
OldsGuy wrote: ........ the first part of the word Cutty Sark which I think is some kind of whiskey ........ Yep, Scotch. Used to be my favorite. Named after the Tall ship Cutty Sark. Quote: ........ I am forever indebted ........
Not a big deal. Only knew about it because I was raised around early Fords.
My Dad still has one.
 Posted: Thu Jun 28, 2007 4:35 am |
lumpy wrote: ........ "my really bitchin' Super Turbine 300" ........ I like it. Can I use it? Quote: ........ I appreciate the grammar corrections ........ Should be terminology instead of grammar. When it comes to things automotive, I have some knowledge of the former. Not qualified to address the latter. Instead of corrections, how about enlightenment? Quote: ........ Are musician and drummer redundant or an oxymoron? ........ Why does the drummer get so little respect? I tried it. Not easy. Quote: ........ which some refer to as a "350 Rocket" in order to avoid confusion with it's GM cousins ........
On any Olds board, a 307, 350, 400, 425, or 455 is an Olds, unless otherwise noted. The one exception has turned into a ghost town during the last year.
My 350 Chev would be a 350, if I posted on a Chev site, but a 350 Chev on a Buick or Pontiac site.
To add one more for future visitors, there is no reason to call my 307, 330, or 350, small blocks, or my 437 and 468s, big blocks.
 Posted: Thu Jun 28, 2007 7:44 pm |
lumpy wrote: Are musician and drummer redundent or an oxymoron?
I have a hard time imagining rock and roll without a beat... Drummers are an excellent asset to any musical group! Besides, I could listen to my brother kick out some awesome beats all day long. Drums are very cool.
OldsGuy
 Posted: Mon Jul 02, 2007 2:20 pm |
Not too bad here in the Kansas City area. All our creeks and rivers held just fine, down in the Southwest is another story! I went down to Pittsburg Kansas on Saturday and it was VERY WET down there. All the rivers, streams, creeks and ponds were way high. My son took his '64 98 fourdoor out of storage and I helped him out some. The trusty 394 fired right up after about three revolutions with the starter motor! The car had been in storage for two years, we did the usual stuff, pre-lube the cylinders, new battery, etc. The master cylinder was dry though and it started to rain before we could bleed the system. Oh well, another day..
