It is currently Tue Nov 10, 2026 10:21 pm
russ12751
 Posted: Fri Jan 16, 2009 10:07 am |
Joined: Sat May 19, 2007 8:38 pm Posts: 30 Location: Jackson Michigan
Welcome to the forum.
_________________ Russ
 Posted: Wed Jan 28, 2009 4:00 pm |
Elad: As stated above, I suggest you start a new thread in the proper forum.
91buickman wrote: ........ i strongly encourage you to see for youreself first ........ Not often you see an "authority" cite his own post, on another site, as a source. 91buickman wrote: Which part deals with this gasket problem? jnb78 wrote:
Better yet, what does anything in that thread, have to do with anything in this one?
91parkave
 Posted: Thu Jan 29, 2009 12:56 am |
88 Coupe wrote: Elad: As stated above, I suggest you start a new thread in the proper forum. 91buickman wrote: ........ i strongly encourage you to see for youreself first ........ Not often you see an "authority" cite his own post, on another site, as a source. 91buickman wrote: Which part deals with this gasket problem? jnb78 wrote: Better yet, what does anything in that thread, have to do with anything in this one? Norm
The hot coolant,mixed with the EGR warps the intake enough to allow coolant through the gasket, and starts slowly to enter the Air intake, causing more problems, it is a knwn design flaw as i stated before. IF you doubt me you can always look it up youreself. plugging the Holes in the LIM are ways to cure this obviously because the coolant never sees the UIM or TB.
To the op it is the same for yours as well. I will find some morre time to dig up some more threads on your problem and what was done to fix it. but i supplied that link to give you an option t o alleviate the problem.
 Posted: Thu Jan 29, 2009 1:15 am |
I'd consider blocking the coolant passages as a last resort, especially since you live in an area that actually needs the coolant going through the throttle body.
A better fix may be to have the surfaces of both the intake and the throttle body "trued up" so that a gasket will seal them better.
Since the car sees cold weather, you'll be better off fixing it right than just "alleviating" the problem.
 Posted: Thu Jan 29, 2009 9:18 am |
I didn't know it got that cold in Georgia.
Here in the Midwest, we've had weeks where it's been -20F to -40F, actual temperature.
The coolant passages are there for a reason. It helps the car warm up, and will help fuel atomization in cold winter temperatures.
 Posted: Fri Jan 30, 2009 12:01 am |
91buickman wrote: 88 Coupe wrote: 91buickman wrote: Which part deals with this gasket problem? The hot coolant,mixed with the EGR warps the intake enough to allow coolant through the gasket ....... I could not find anything either. 91buickman wrote: ........ it is a known design flaw as i stated before ........ You have "stated" a lot of things since your arrival. Few of your statements have had anything to do with reality. 91buickman wrote: ........ i supplied that link to give you an option t o alleviate the problem. 1. The link has nothing to do with the "problem". 2. The OP has not yet defined the "problem". Norm
 Posted: Fri Jan 30, 2009 1:42 am |
91buickman wrote: ........ I will find some morre time to dig up some more threads on your problem and what was done to fix it ........ Here is one that tells how to do it. http://www.3800pro.com/forum/naturally- ... 6df8460a54But it doesn't say why. 91buickman wrote: i disagree my car still warms up in the same amount of time ........
It it is wonder that it warms up, at all.
 Posted: Fri Jan 30, 2009 2:47 am |
andrewk wrote: ........ especially since you live in an area that actually needs the coolant going through the throttle body ........ From 91buickman's link: http://www.3800pro.com/forum/supercharg ... sc-tb.htmljnb78 wrote: ........ I live in yuma AZ its really hot ........ Yuma, AZ? Hot? 91buickman wrote: theres alot of debate about this as well but for your climate, i'd block it off ........ Debate? For your climate? Yuma, AZ? How does the weather in Yuma, AZ compare with Milwaukee, WI? What does any of it, have to do with a gasket failure? andrewk wrote: ........ A better fix may be to have the surfaces of both the intake and the throttle body "trued up" so that a gasket will seal them better ........
Makes perfect sense if the gasket is the only problem.
We should be able to get it clarified when the new thread is started.
