It is currently Wed Nov 11, 2026 11:12 pm
 Post subject: Hi There!
PostPosted: Wed Aug 20, 2008 12:31 pm
Hey everybody,
I just got a great deal on a '99 88 anniversary edition. I'm joining so I can get tips on how to keep it looking and running like new. The car didn't come with door remotes. I bought the right ones on ebay, but I don't know how to program them. Any ideas?
 Post subject: Re: Hi There!
PostPosted: Wed Aug 20, 2008 3:01 pm
Welcome to the Olds connection!
I can certainly help you with your issue...
Keyless Entry: Service and Repair
IMPORTANT: Before entering the programming mode, verify possession of all the transmitters you will be using on the vehicle. Once you program
the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4
transmitters.
Perform the following procedure when adding new transmitters or replacing failed transmitters:
1. Turn the ignition switch OFF.
2. Use a fused jumper in order to jumper the DLC terminal 8 (BLK/WHT) to terminal 4 (BLK).
3. Close all of the doors.
4. Turn the ignition switch ON. The doors will cycle to lock.
5. Press and hold the LOCK button and the UNLOCK button on one transmitter.
After a 30 second delay the doors will lock and unlock.
IMPORTANT: Do not turn the ignition OFF or the first transmitter will become inoperative.
6. In order to program extra transmitters, repeat step 5.
7. Disconnect the jumper from the DLC.
