It is currently Sat Oct 24, 2026 9:59 pm
 Page 1 of 1 [ 11 posts ]
PostPosted: Mon Feb 05, 2007 10:59 pm
LOOKING FOR 1951 OLDS SPARK PLUG WIRE HOLDERS
PostPosted: Tue Feb 06, 2007 4:09 pm
Hi Keefer, hello everyone,
I was not going to reply because of your inappropriate use of caps. I will, however, point out your other error.
The image shows a 4 door Sedan, while the caption, incorrectly, reads Holiday.
PostPosted: Tue Feb 06, 2007 6:29 pm
if you don't know your oldsmobiles why are you on this site
PostPosted: Tue Feb 06, 2007 6:50 pm
Interesting answer.
keeffer wrote:
If you don't know your Oldsmobiles, ........
Interesting assumption.
keeffer wrote:
........ why are you on this site.
Interested in learning about Oldsmobiles, and Clowns.
PostPosted: Wed Feb 07, 2007 8:27 am
In case anyone is interested, the above image was added while I was composing my last.
In it, I do not see where it shows the car to be a Style # 3967 (4 door sedan) or Style # 3969 (Holiday).
One does not have to "know Oldsmobiles", to realize that, by nature, commercial ads are not the most accurate means of communication.
Alternatively, Olds/GM is recognized as the most accurate source, and the FSM (Factory Service Manual) is one of the handiest, and most valuable of its resources.
PostPosted: Wed Feb 07, 2007 9:07 am
the pic is from my 1951 olds dealer brochure if that is not correct than what is
i don't understand your problem don't you thing i know what i have ownered this was my grandmothers first new car was she dumb and not know what she bought and get a life
PostPosted: Wed Feb 07, 2007 9:31 am
keeffer wrote:
the pic is from my 1951 olds dealer brochure ........
I have seen them before.
keeffer wrote:
........ if that is not correct, then what is ........
As I said above, it is not. Anything that actually came from the factory is.
keeffer wrote:
........ i don't understand your problem ........
That would be because I do not have a problem.
keeffer wrote:
........ don't you think i know what i have ........
If you did, you would have captioned your image correctly, and I would not be writing this.
keeffer wrote:
........ this was my grandmothers first new car ........
I am happy for you.
keeffer wrote:
........ was she dumb and not know what she bought? ........
We can assume she knew exactly what she bought. It is obvious you do not.
keeffer wrote:
........ and get a life.
I have one, thank you.
PostPosted: Fri Feb 09, 2007 11:35 pm
In case anyone is interested.
........ I do not see where it shows the car to be a Style # 3967 (4 door sedan) or Style # 3969 (Holiday) ........
That Style Number will be at the top left, on the cowl tag.
The cowl tag is on the firewall, adjacent to the upper, driver side, door hinge. It is where one would find all the "numbers matching" information.
They can be decoded, using the FSM for that year.
PostPosted: Sat Apr 28, 2007 3:03 am
Correction:
........ They can be decoded, using the FSM for that year. ........
They can also be decoded using the Factory Parts Manual. I recently learned it disagrees with the FSM.
Olds only used the "Holiday" name for Hardtop Convertibles, from '49 into the 80s. '51 "98" 4 door Sedan was the one exception. FPM called Style #3967, a "Holiday"
So, it appears that keeffer was correct.
PostPosted: Mon Apr 30, 2007 7:52 am
Are you looking for the "flattened tube" device that houses the plug wires on a straight six? If so, I have one.
PostPosted: Mon Apr 30, 2007 9:23 pm
'51s were all V8s. '50 was the last year for the Big Six.
He probably meant these. They fit in the '51 to '60 stands, and are not the same as the '49 to '53 separators that mounted on the rocker covers. All three items could be called "holders".
