It is currently Sun Nov 22, 2026 11:13 pm
 Page 1 of 1 [ 7 posts ]
 Post subject: big block olds
PostPosted: Sun Apr 06, 2008 1:13 pm
I am looking for a oldsmobile 425ci crank shaft--late 60's-early 70's
 Post subject: Re: big block olds
PostPosted: Sun Apr 06, 2008 7:19 pm
Hi mechanic_28,
400/425 crank was only used from '65 to '67. In good condition, they are probably worth $150 max.
Ebay and Craigslist are probably the best sources, followed by Real Olds Power.
PostPosted: Sun Apr 06, 2008 7:45 pm
Hi mechanic_28,
At the bottom of this thread user "Blownolds" says he has a couple- You have to register to use the PM functions and all, and sometimes it takes awhile to register on ROP. If you need a laison to get you in contact, PM me to let me know; I'd be glad to help.
Welcome to TOC-
PostPosted: Sun Apr 06, 2008 9:08 pm
The 400 crank is different from the 425 crank,must have 425 crank to put in my 455 to make a stroker engine. But thanks for the help.
PostPosted: Sun Apr 06, 2008 9:43 pm
mechanic_28 wrote:
The 400 crank is different from the 425 crank ........
How is it different?
........ must have 425 crank to put in my 455 to make a stroker engine ........
Stroker? An internet term that is all but useless.
400/425 stroke is 4" and 455 stroke is 4¼". A 425 crank in a 455 will get you 425 inches.
What is it, that you wish to accomplish?
PostPosted: Sun Apr 06, 2008 10:46 pm
The late 400 crank is the same as the 455 isn't it (Cast, 4.25 stroke)? The early 400, IIRC should be forged with the 4" stroke, the same as the 425?
PostPosted: Sun Apr 06, 2008 11:53 pm
........ The late 400 crank is the same as the 455 isn't it ........
It is.
3.870" x 4.25" = 68-69 400ci
4.126" x 4.25" = 68-76 455ci
........ The early 400, IIRC should be forged with the 4" stroke, the same as the 425? ........
Unless he knows something we do not.
4.000" x 3.98" = 65-67 400ci
4.125" x 3.98" = 65-67 425ci
