It is currently Sun Nov 22, 2026 11:13 pm
 Page 1 of 1 [ 8 posts ]
PostPosted: Mon Apr 28, 2008 11:32 pm
4-28-08...
Two Factory Versions Of Harmonic Balancers Were Made Then:
1957 Oldsmobile 371 c.i. V-8...G M C # 569170 (3 Grooves) Slots Rear
1958 Oldsmobile 371 c.i. V-8...G M C # 569168 (2 Grooves) Slots Rear
If You Have Or Know Of Source...
E Mail Me: meanmotherusac@aol.com
Visit Me At: http://www.MeanMother.Com
Check Out: The Blast Into The Future
Thank You For Any Information...
MeanMotherUSA
BORN UNDER HOOD OF A CAR...
PostPosted: Sat May 03, 2008 10:55 pm
MeanMotherUSA wrote:
........ Two Factory Versions Of Harmonic Balancers Were Made ........
For the, externally balanced, 303/324 based 371, only. Three belts for Air conditioning, two belts for non AC.
Your profile shows an Olds with Tr-Power. Is it a Pontiac engine, or was a Pontiac manifold adapted to an Olds?
Or is there another explanation?
PostPosted: Tue May 06, 2008 3:19 am
5-6-08...
NORM
It Is Olds 1957 371 c.i. V-8 Engine , i.e. Either Olds G M C Part #'s Above I Listed = Harmonic Balancers Will Work Irrespective Of Belts Or A C...
1957 Version (See My Photo) Fits 1957,1958,1959,1960 371 c.i.V-8 Engines...
Thanks...
MeanMotheruSA
PostPosted: Fri May 09, 2008 5:38 am
........ NORM ........
Your use of caps is unnecessary.
........ It Is Olds ........
In that case, I'll repeat the second, and third, parts of the question:
........ or was a Pontiac manifold adapted to an Olds?
Or is there another explanation? ........
Since J-2 manifolds/carbs are more plentiful, I see no reason to adapt a Pontiac manifold to an Olds engine.
........ Irrespective Of Belts Or A C ........
OK, you do not have air. This one should work for you.
........ 1957 Version (See My Photo) ........
Not very useful. Could be anything from '49 to '58. Your valve covers are '49/'50.
........ Fits 1957,1958,1959,1960 ........
Yes. Both 303 and 394 based 371 should use the same balancer. Damper Doctor will know for sure.
PostPosted: Fri May 09, 2008 6:33 pm
5-9-08
NORM:
My Valve Covers Are 49/50 Because I Have Hi-Lift Engle Cam, Solid Lifters And Isky Adjustable Rockers ( Fit Easier Under Covers ) Ain't Got Nothing To Do With Anything...
It Is 371 c.i. V-8 Engine 4 bbl Or Tri-Power Carburetors Is SAME,i.e. The Harmonic Balancer In Photo Will Fit: 1957,1958,1959,1960 371 c.i. V-8 Engines...
G M C Are Factory Numbers, For 1957 & 1958 Harmonic Balancers...They Can Be Rebuilt, But I Need Used Or New For My 2nd Engine Building Now...
MeanMotherUSA
PostPosted: Fri May 09, 2008 9:20 pm
........ 49/50 Because I Have ........ ........ Isky Adjustable Rockers ........
No problem with oil leaks?
Isky was the only one with the adjuster on the bottom. It was so it would fit under all Olds valve covers. Good for "sleeper" situations.
I used factory adjustables and "dimpled" covers with my Isky cam.
........ Ain't Got Nothing To Do With Anything ........
A simple comment. Nothing more, nothing less.
........ It Is 371 c.i. V-8 Engine 4 bbl Or Tri-Power Carburetors Is SAME ........
Is English your second language?
PostPosted: Sat May 10, 2008 4:27 pm
5-10-08...
I Just Can't Deal With 3rd Grade Mentality...I Write For A Living $...
What In Hell Are You Rambling On & On About!?
Is Espanol Englese Your 1st Language... You Pretend You Think You Know What You're Talking About...Forget It...
MeanMotherUSA
PostPosted: Sun May 11, 2008 3:46 am
........ 3rd Grade Mentality ........
Explain.
........ I Write For A Living $ ........
In a language other than English?
........ What In Hell Are You Rambling On & On About!? ........
I asked a couple of simple questions.
Questions that you do not seem to be capable of answering.
........ Is Espanol Englese Your 1st Language ........
English is my only language.
I do not use it, to flame/insult/deride someone who asks me a simple question.
I do use it, to answer any/all questions, about my posts, posed during a forum discussion.
It is the way adults comport themselves.
........ You Pretend You Think You Know What You're Talking About ........
You have me confused with 91buickman.
I was simply asking how you got a Pontiac intake manifold to fit your Oldsmobile engine.
