It is currently Sun Nov 08, 2026 2:36 am
 Page 2 of 2 [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: Tap and Die set...
PostPosted: Sun Nov 12, 2006 10:14 am
Hi Norm, all,
Sorry for not getting back sooner.
88Coupe wrote:
Was it the tap's fault?
Yes and no. I believe the threads in the block were rolled, not cut, so it was nearly impossible to not remove material.
It also wasnt the taps fault because I should have known better.
PostPosted: Mon Nov 13, 2006 7:58 am
........ I believe the threads in the block were rolled, not cut ........ ........ so it was nearly impossible to not remove material ........
Taps are self centering by design.
If you used cutting oil and kept the chips blown out, you should have cut into the root, and at worst, only polished the flanks.
........ wasnt the taps fault because I should have known better.
Not where I was going. Are you sure there was no problem with the casting or threads, going in?
Did you use a tap because you were in a hurry?
PostPosted: Mon Nov 13, 2006 10:24 am
I didn't use any oil. That could have been the problem.
No. At that point, I didnt know there was a difference between a tap and a chaser.
PostPosted: Mon Nov 13, 2006 10:33 am
........ At that point, I didn't know there was a difference between a tap and a chaser.
I don't know that I did either, until you brought it up.
