It is currently Wed Nov 11, 2026 3:49 pm
 Page 2 of 5 [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Sep 28, 2004 1:55 pm
I agree, lets seem some flames!!!!!
PostPosted: Tue Sep 28, 2004 2:40 pm
I don't... :laughing:
PostPosted: Sun May 15, 2005 3:27 pm
Now that we know it's getting into the carb, you need to verify if its getting through the jet and is being sucked into the airflow as it passes through the carb.
The primer bulb test indicated there is adequate airflow.
Ok...back to lawn mower maintenance....
It is getting air flow, that's for sure, as I can put the throttle high once I get it started with the primer bulb and it will rev higher....but then it stalls out a lot quicker too...so lack of fuel. Thing that puzzles me is that I've taken this carb apart about 5 times now... :lol:
I haven't tried carb cleaner yet though, only compressed air. As I said before, the bowl is full of gas when I take it apart. What passage could be blocked?
PostPosted: Sun May 15, 2005 6:17 pm
Hi Brando, all
I've been wondering about your progress.
There should be a small opening in the venturii. It should lead to the jet in the float bowl.
If you blow compressed air in the wrong direction you can lodge an obstruction even tighter. Carb cleaner might help break it up and let it go all the way through.
If the correct amount of fuel gets through and it's mixed with the right volume of air, it will run.
PostPosted: Fri May 20, 2005 7:59 pm
OK...UPDATE!
I got it running for more than .5 seconds and no need for the primer bulb. Sprayed ALL the passages in the carb with carb cleaner....did the trick.
Only problem now is, it seems as if the timing is incorrect?
I checked the spark plug gap, it is correct. Gapped the coil with a business card, which I've heard works and gives the correct gauge. The flywheel key has been changed. What else could it be?
Here is what happens. I start it...starts up pretty quickly, but it just doesn't have a consistent idle. I put it on full throttle and it runs for a while, but will stall out unless I put the throttle back down (although sometimes it still stalls). I got my backyard cut...because the grass is pretty much dead back there and there isn't much. The front grass is THICK, and I only got a little bit cut, as when it got to the thicker parts it didn't want to cut it. Is there a key in the blade?
This is a Toro 16793 to be exact.
PostPosted: Fri May 20, 2005 9:47 pm
Hi Brando, all,
......... I start it...starts up pretty quickly, but it just doesn't have a consistent idle. I put it on full throttle and it runs for a while, but will stall out unless I put the throttle back down (although sometimes it still stalls)
I've gone as far as I can.
I'll be looking forward to reading about your final fix, as my 15 year old Craftsman started doing the same thing, last Tuesday.
PostPosted: Sat May 21, 2005 7:02 pm
This article has helped me a lot:
http://www.eio.com/repairfaq/sam/lmfaq.htm
* With the carburetor body inverted, check the float height adjustment.
It should seat almost horizontally. For a more precise test, use a
.210" (#4) drill bit as a gauge across the outer ring of the carburetor
body - the float should just touch this. Bend the tab on the float to
adjust. (Note: unless you replaced some parts, this setting will probably
be fine.)
I did replace the float...so I'll give this a try.
* Place the bowl over this assembly making sure that it does not pinch
the O-ring. Orient it so that the deep part is almost opposite the
float hinge (it should actually point directly away from the engine
when the carburetor is mounted.)
Didn't know this.
This info comes from the Cleaning Craftsman (Tecumseh) carburetors part of that article.
PostPosted: Sat May 21, 2005 7:44 pm
I didnt know that lawn mowing could involve so much lol my 16 yr old Craftsman 4 hp mower (complete with a 3 inch long, .5 inch wide hole in the body and the bag is long gone) starts right up. I dont even change the oil since it leaks so much i keep topping it off every month lol.
PostPosted: Sat May 21, 2005 7:54 pm
Hi Brando, All.
.......... Place the bowl over this assembly making sure that it does not pinch .........
Sounds like, if the "O" ring were pinched it would create a vacuum leak.
Your symptoms sound like a vacuum leak.
Coincidence?
Since I have no experience with lawn mowers, I'll wait and see what you find.
PostPosted: Sat May 21, 2005 8:34 pm
No, it wasn't the O-Ring being pinched what I didn't know...I made sure that went on right. It was the float needing to be adjusted and also, the deepest part of the bowl facing opposite from the float hinge. I also cleaned the hole in the bolt that holds the bowl on, as recommended in that article, with a tooth pick and carb cleaner...as well as compressed air. She purs like a kitten now. Starts up right away. HOT DAMN! :lol:
Weed Eater GTI 15T and Toro 4HP Lawn Mower in top condition! :D
PostPosted: Sat May 21, 2005 9:42 pm
Hi Brando, all
........... It was the float needing to be adjusted .......... Starts up right away ..........
That's good news.
Since mine came on with no warning, I'll look for a pinhole in the float. First I need to find the float.
PostPosted: Sat May 21, 2005 9:51 pm
Can't miss it! When you open up the carb, it's the huge ring.
PostPosted: Sat May 21, 2005 9:53 pm
:lol:
PostPosted: Mon May 23, 2005 7:09 pm
Well, I missed it I guess... I have ben really busy and havent been on in a few days. Glad its all working, and if it makes you feel better, the suggestions I would have made were what you wrote above about float level, etc. Sorry I couldnt help, Ill try to be on more often to help out with the lawnmowers.... :lol: :roll: Norm, I would also look for a bad needle and seat. Invert the carb and blow through the fuel line. If the needle doesnt hold light pressure, the replace it. If you have a thumb pump, just use that. Needle should hold .05 psi I believe. For as cheap as the part is, you might as well replace it while its apart. If you are taking it apart anyway, also remove the main jet (if its removable) and spray it out and blow it all out. I also run a small wire through all the small passages to insure that they are clean. Hope this helps.
Peace!
PostPosted: Mon May 23, 2005 9:30 pm
Thanks andrewk,
