It is currently Tue Nov 10, 2026 2:06 pm
 Page 3 of 3 [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Apr 03, 2006 12:35 am
DrRansom442 wrote:
OK so I must have been sleeping or staring at the achitecture of the Chrysler building when Rockefeller came up in history, but I remember the signs
and this is where I went estray. Didn't realize long before that the were part of the same conglomerate. Way to keep me on my toes, BTW Exxon/Mobil isn't a monopoly, according to Fortune .... BP is still bigger (#2) but Exxon/Mobil (#3) is more proffitible Also Shell (#4) Total (#10) round out the top 10.
I didnt mean to imply that they were a monopoly... just that they are a corporate giant, very similar to that of the Standard Oil conglomerate of the late 1800's. Little did I know that they were once owned by standard... I guess you learn something everyday...
PostPosted: Mon Apr 03, 2006 12:55 am
DrRansom442 wrote:
LT5? the 89-95 ZR-1 engine has NOTHING in common with anything from the 1950s, its not even technically a Chevy engine and shares nothing with the architure of the SBC.
The LT5 was an aluminum creation of Lotus (at the time owned by GM), built by Mercury Marine... ... I will conceded that since the LT-5 was a 32 valve DOHC engine ... 16 intake runners would make sence.
I have to agree... according to wikipedia... (I edited out the flames, as I have no "beef" with Norm)
http://en.wikipedia.org/wiki/Chevrolet_Corvette
Now where is this 16 port SBC intake from the 1950s? Perhaps you are thinking of Zora Arkus Duntov's experimental DOHC SBCs he was hoping would be used competitively in the Grand Sport Corvettes of 1963-1967 that raced Le Mans ... these engines not only didn't see use competitively, they were certainly not availible to the public ... in fact I had read an old old copy of Hot Rod (no I do not have a copy to scan), these engines weren't even seen by the public till 1975 (Zora's retirement). Again even if my assumption is correct, they have no commonality to a LT-5
Its always best not to assume. I cant find anything on the net about this intake, and I dont think it is fesiable for you to expect him to prove it. I believe him[Norm], he has yet to make me think otherwise.
PostPosted: Fri Apr 07, 2006 12:34 am
Hi All,
Another correction.
Need to make a couple of corrections.
........ Earlier (possibly '82) Corvettes used a manifold with two runners to each intake port. One was used for normal driving, both for max power. It was a variation of an early '50s street/strip design by Offenhauser. They achieved a significant improvement with the use of the computer ........
I inadvertently used the name Offenhauser above, I should have used the name Weiand in it's place. Fortunately the name makes no difference, as the description (such as it is) is accurate.
Found out today, the manifold I referenced was, indeed, an Offenhauser offering.
It seems, I was in error when I pointed out my own mistake.
