It is currently Wed Nov 11, 2026 3:07 pm
 Page 3 of 5 [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Apr 05, 2006 11:29 am
Images: 5
Despite all these differences, all these intakes posted here (except the LT-5) have one thing in common. 8 intake runners for 8 intake valves... not 16 as was presumed.
DrRansom442 wrote:
BTW that Crossfire manifold isn't stock, its been "machined"
I know, I said that when I posted them in the CFI thread... I couldnt find good shots of a unmolested one, so thank you for providing those.
you are exactly right Andrew, but as I've said all along the CFI is the only 'vette intake I know that share simular design to an old Offy or Weiand ...btw I missed the new thread, my bad
3 time G-body owner
PostPosted: Wed Apr 05, 2006 2:36 pm
Thus the confusion...
88Coupe wrote:
Earlier (possibly '82) Corvettes used a manifold with two runners to each intake port. One was used for normal driving, both for max power. It was a variation of an early '50s street/strip design by Offenhauser. They achieved a significant improvement with the use of the computer.
So it appears that Norm was perhaps confused? He mentions the LT-5's "valet" mode, but maybe incorrectly recollects year and design? Not going to speak for him... I let him explain further if he chooses too.
I think we have reached the end of the tunnel.
PostPosted: Wed Apr 05, 2006 4:02 pm
Images: 5
Hooray!!!!!!!!!!!
3 time G-body owner
PostPosted: Wed Apr 05, 2006 11:04 pm
Hi Andrewk, All,
DrRansom442 wrote:
LT5? the 89-95 ZR-1 engine has NOTHING in common with anything from the 1950s, its not even technically a Chevy engine and shares nothing with the architure of the SBC ........
Did anyone say it did?
DrRansom442 wrote:
........ but as I've said all along the CFI is the only 'vette intake I know that share simular design to an old Offy or Weiand ........
CFI shared a nearly identical design (all differences were cosmetic) with at least 4 crossram manufacturers.
How does that relate to my original statement?
Andrewk wrote:
........ So it appears that Norm was perhaps confused? ........
Are you sure I'm the one that's confused?
Please post a link to the source of those pix.
2 EDITS: Used the edit, instead of the quote button. Then had to repair the damage.
PostPosted: Thu Apr 06, 2006 11:01 pm
Hi andrewk, All,
........ I’m sure what Norm was referring to in his initial post about an intake with 16 runners for a v-8, was not CFI ........
........ Earlier (possibly '82) Corvettes used a manifold with two runners to each intake port. One was used for normal driving, both for max power. It was a variation of an early '50s street/strip design by Offenhauser. They achieved a significant improvement with the use of the computer ........
Did I say it was for a V8?
PostPosted: Thu Apr 06, 2006 11:10 pm
No Im not.
No you didn't. Is it? Please explain.
PostPosted: Fri Apr 07, 2006 12:35 am
Hi All,
Another correction.
Need to make a couple of corrections.
I inadvertently used the name Offenhauser above, I should have used the name Weiand in it's place. Fortunately the name makes no difference, as the description (such as it is) is accurate.
Found out today, the manifold I referenced was, indeed, an Offenhauser offering.
It seems, I was in error when I pointed out my own mistake.
PostPosted: Fri Apr 07, 2006 1:56 am
Hi andrewk, All,
No Im not.
Sorry, that should have been phrased differently. I didn't intend it to be rude.
No you didn't. Is it? ........
Not only SBC, and not only V8.
Answers to just two of the many questions DrRansom442 should have asked, before, starting his BS posts.
BTW: Not much chance he'll post a link to the source of the pix. I don't think he wants us to see its accompanying article. Kinda like DrJay and his "venders" site.
PostPosted: Fri Apr 07, 2006 3:09 am
Hi andrewk, All,
No Im not.
No offense taken :wink:
Interesting... So it had 2 intake runners to each intake port? How did it work?
What other engines/sizes was it offered on? Sounds like an interesting piece of equipment...
PostPosted: Fri Apr 07, 2006 5:41 am
Hi andrewk, All,
........ Interesting... So it had 2 intake runners to each intake port? How did it work? ........
Similar to the induction setup on those Corvettes that used a manifold with two runners to each intake port. One was used for normal driving, both for max power.
........ What other engines/sizes was it offered on? ........
Perhaps, I'll answer this one after DrRansom442 posts the link I requested. It would fit in here perfectly.
........ Sounds like an interesting piece of equipment...
Less complicated than the induction setup on those Corvettes that used a manifold with two runners to each intake port. One was used for normal driving, both for max power.
Less complicated than the Crossfire, also.
PostPosted: Fri Apr 07, 2006 9:17 pm
Hi 85cieraholiday, All,
Sorry for the delayed response to the balance of your post.
........ asking DrRansom442 for stuff he has already given ........
DrRansom442 made the same declaration several times but, after repeated requests, he has been unable to post any quotes.
If you can, please do.
........ and your starting an argument over nothing ........
Fact 1: DrRansom442 made three false statements in the original thread.
Fact 2: DrRansom442, has not attempted to acknowledge, clarify, or even discuss the validity of those statements in any way.
Fact 3: DrRansom442 has gone to extreme lengths, to avoid dealing with his own falsifications, up to and, including character assassination.
Do you think anyone should be allowed to perpetuate "urban myths" "wives tales" and any other forms of "internet misinformation", without being challenged?
If so, please explain your logic.
........ It takes a big man to admit your wrong, I think you should do so ........
I repeat: I will admit I'm wrong, when I am actually wrong.
PostPosted: Fri Apr 07, 2006 9:24 pm
So it is similar in the fact that the offy version does it mechanically, and the LT-5 with the ECM? That would make the fact that they both have 16 intake runners coincendental right? (Since the LT-5 is DOHC, and would be unable to "shut off" or not use one set of intake runners?)
Just making sure I am understanding this correctly.
PostPosted: Sat Apr 08, 2006 1:59 am
Hi andrewk, All,
So it is similar in the fact that the offy version does it mechanically, and the LT-5 with the ECM? ........
The more I edit this, the more similar they get. They both do it mechanically.
The computer closes one intake valve which limits the volume of air to the combustion chamber, while keeping the velocity up.
The carb closes one runner which limits the volume of A/F mixture to the combustion chamber, while keeping the velocity up.
........ That would make the fact that they both have 16 intake runners coincendental right? ........
Not a coincidence. Using 16 runners for velocity control is the reason they are functionally the same.
EDIT: It's possible that one uses ⅜" bolts and the other uses 10mm, but that is DrRansom442s area of expertise, not mine.
........ Just making sure I am understanding this correctly.
I'm glad you're interested. Many times I gain a better understanding of a subject by explaining it to someone else. I this case I've learned a lot.
In addition to furthering our knowledge, your questions demonstrate to TOCs more astute readers, the difference between a discussion and an argument.
PostPosted: Sun Apr 09, 2006 12:36 am
Images: 5
I said I was done with norom's nonsense and misinformation but once again here i am
Norom, the ONLY non V-8 Corvettes were 53/54s (these cars had Blue Flame I-6s with 3 side draft Carters - definately not the 16 runner Offy inspired Corvette intake you keep claiming exists). So yes, by process of elimination we are talking strictly V-8. Again $50. can be yours by posting this picture.
This is not how the LT5 operates, where you concocked this out of the "valet mode" is mesmerizing. When the "full power mode" is switched off the ECM merely limits the fuel and timing in "valet mode". This is NOT like the V8-6-4 were valves were physically (magnetically if memory serves) held shut
Andrew is DEAD ON. the LT5 has 16 runners because it has 16 intake valves ... all runners are open, all 4 cams turn and all 32 valves open and close when the engine is running .... if they stop, call a tow truck. My claims can be substatiated Norom, its all common knowledge. Unlike you I don't have to invent stuff to sound like I know what I am talking about. Andrew pointed out on another thread i was wrong, and I admitted it, why can't you play the grownup too and admit, I got you .... over and over. The more Corvette "facts" you post, the further you dig yourself in and the more you prove you are a HACK
3 time G-body owner
PostPosted: Sun Apr 09, 2006 1:36 am
Hi andrewk, All,
Just noticed these while looking for the above image for your CFI only thread.
DrRansom442 wrote:
........ examples
1) design of plenum
2) location of T-stat housing (there is a 90 degree difference)
3) lack of EGR provisions
4) larger runners
5) slope of runners
6) lack of factory "stamps" (i.e. firing order)
7) height
8) number of plenum bolt holes
I'm sure I've missed somethings, but like I said, my eyes aren't the best ........
Thanks for posting the pix, and for pointing out some of the many cosmetic differences ........
I really need to learn how to use those smileys.
Those "many cosmetic differences" have nothing to do with any comparison between the designs or operation of all five manifolds.
Despite all these differences, all these intakes posted here (except the LT-5) have one thing in common ........
They have everything in common except those differences.
........ OK. What's the difference? ........
The question was rhetorical.
Examination of the above pix show the layout is the same. Other than cosmetics, all four Crossrams and the Crossfire are the same design.
DrRansom442 wrote:
........ you just PROVED you don't know what you are talking about, that is not a crossfire injection manifold that is one of the 3 Offy crossram pictures I posted, that you say never existed, why don't you for once admit you are wrong ........
It doesn’t matter which image I used. You posted it, it was handy, and it illustrated my point. Which, by the way, you missed.
I’ll admit I’m wrong when I’m actually wrong.
