It is currently Thu Nov 12, 2026 4:10 pm
 Posted: Thu Mar 23, 2006 4:09 pm |
Had an ingrown toenail removed yesterday....that sucker was DEEP!
I suppose it being an ongoing problem and me doing my "home remedies" since I was twelve didn't really help.
Anyone else had this done before?
 Posted: Thu Mar 23, 2006 6:24 pm |
that would be about as fun as getting your wisdom teeth removed (I'm going to have to do that right away)... Pain is your friend. It lets you know you're still alive.
 Posted: Fri Mar 24, 2006 4:41 am |
by home remidies, do you mean cut it out yourself?? I have done that lots of times... I just get the knife real hot so it doesnt hurt so much...
 Posted: Fri Mar 24, 2006 10:53 pm |
Yea...I clipped it out...it worked for a while, but this time there was nothing to clip..it was deep down.
A hot knife?
 Posted: Sat Mar 25, 2006 4:32 am |
Brando wrote: A hot knife?
yep, and needle nose pliers to grab alold of it... the knife being hot also codderizes the skin so as to minimize blood loss... pre op procedure invloves a few shots of whiskey.
 Posted: Thu Mar 30, 2006 2:46 pm |
Coldfire wrote: Jebus! That's scary...I suppose the key is to balance the max amount of whiskey to minimize the pain, while still being coherent enough to not make it worse
exactly...
