It is currently Tue Aug 25, 2026 5:16 pm
 Posted: Mon Apr 17, 2006 6:55 pm |
List em up....tell stories....whatever
Toro 16793 Lawn Mower - TNT100 Tecumseh Engine 4HP - electric start
Weed Eater GTI 15T
Craftsman 25cc/17" weed whacker along with 12 foot pole pruner and edger attachments
Craftsman 25cc/200MPH Leaf Blower
Craftsman 32cc/205MPH Leaf Blower/Vac
Stihl 029 Super Chain Saw
87Delta
 Posted: Mon Apr 17, 2006 7:19 pm |
Hum, what I got...
1998 (?) Craftsman Self-Propelled 6.5HP Mower - Briggs
2004 Craftsman DRM500 Rear Engine 10HP Mower - Briggs
1999 Stihl FS 36 Weed Eater
and lastly my Ryobi Weed-Eater which is ported, has open exhaust, and runs off of racing alchohol
 Posted: Mon Apr 17, 2006 8:51 pm |
What I bought, that my parents use while I am at college...
2002 Simplicty Legacy Garden Tractor, 4WD 3cyl, 27.5hp daihatsu deisel (built for briggs), 60 inch shaft drive deck, shaft drive hydro, rear 540 pto. (My parents helped (read: bought, with my discount and advice) with this one... its one helluva lawn mower... you should see the hydraulic lift snowblower with electric spout adj... this thing is trick!)
2000 lawnboy gold series cast deck 2 cycle selfpropelled push mower
(last year for the 2 cycle and offset deck)
2000 Sthil fs120 trimmer
2000 Sthil SH85 blower/shredder
2001 Sthil MS280 chain saw, 20 inch bar.
I either bought or made my parents buy top of the line stuff so they I (and for now, they) would have something that will last, and do a good job. IMO, nothing cuts better than a simplicity deck. People rant and rave about how good John Deere is, but I say they make 'em green so they can hide in the grass when a good one goes by.
Working as an outdoor power equipment technicial really lets you know what is good and what is junk. Granted, the cheap stuff does the job, but people dont realize that they are meant to be thrown away, not fixed.
Brando, that is a helluva good saw you have... old too... I take it the Toro still works good?
 Posted: Tue Apr 18, 2006 8:25 am |
andrewk wrote: ........ hydraulic lift snowblower with electric spout adj ........
What's a snowblower? Come to think of it, what is snow?
 Posted: Tue Apr 18, 2006 10:44 am |
88 Coupe wrote: andrewk wrote: ........ hydraulic lift snowblower with electric spout adj ........ What's a snowblower? Come to think of it, what is snow?
Rub it in Norm.... Rub it in...
Turbocharged400sbc
 Posted: Sun Apr 23, 2006 3:16 am |
andrewk wrote: 88 Coupe wrote: andrewk wrote: ........ hydraulic lift snowblower with electric spout adj ........ What's a snowblower? Come to think of it, what is snow? Rub it in Norm.... Rub it in...
nice....yeah, just remember someday....eventually....very far in the future...the pacific plate will have moved you (ok, Cali, "land of fruits and nuts"...you may not be there) to alaska.
any way to the topic
smallest to biggest...
torch (fer burnin stuff duh....)
5 gallon gas can (multiple uses)
32cc 2 cycle Weed-eater....ollld runs perfectly
lawnboy 2 cycle mower
ollld craftsman 3 stage snowblower 26 inch tall 30 inch wide has power forward and reverse, i got it after someone put an 11Hp tecumseh on it-doesnt look stock...needed the carb rebuilt and a connecting rod...i have brass shimstock in it and it has 2 winters so far just tappin away...
my 5.5HP HOnda/11HP troybilt rototiller powered go cart for doing lawn jobs
and the big azz troybilt 11hp tecumseh engine (i also use it on the cart) this is my prize...i went through the engine ported and polished decked the head (hours with a plate of glass and sheets of sandpaper....hours  ) from the way it tilled before to the way it does now...an easy 13-14hp the tines measue 28 inches in diameter and 30 inch wide path, and weighs about 250+ lbs. it used to have issues before the rebuild but now it'll tear a 3/4 inch root no problem....and procede to drag your ass all the way accross the yard...even in high gears...its kinda fun actually....
i have access to a 64 Harley davidson golfcart...dragstrip duty i get to use it whenever i need cause i'm the reason it runs in the first place...
75 Jeep parts: lawn ornament and iron oxide farming
uhhh im gonna stop there....no need to talk about the tires and stuff (i technically have to call it equipment
yeah thats about it....
oh and my right middle fingers swelling has went down...its now only twice the size it used to be....and the final color is a dark purple fading to a dark red at the edges
time fer some more shots...gnite all
 Posted: Sun Apr 23, 2006 4:11 am |
Turbocharged400sbc wrote: ........ Cali, "land of fruits and nuts" ........
Yeah, and don't forget all the "trannys".
87Delta
 Posted: Sun Apr 23, 2006 11:25 am |
88 Coupe wrote: Turbocharged400sbc wrote: ........ Cali, "land of fruits and nuts" ........ Yeah, and don't forget all the "trannys".
Norm must be eyeing "trannies" oh boy
Just kidding..
Turbocharged400sbc
 Posted: Sun Apr 23, 2006 2:05 pm |
RednBlackCutlass wrote: I got a post hole digger. I used it to dig a hole for this post.
i USED to think that humor could never get so dry....
 Posted: Sun Apr 23, 2006 7:46 pm |
Excellent choice of tools for the job.
 Posted: Thu May 04, 2006 6:04 pm |
andrewk wrote: Brando, that is a helluva good saw you have... old too... I take it the Toro still works good?
Digging this topic back out of the hole....
Yes, the Toro lawn mower still runs great....haven't had to do much of anything to it except clean the carb out (all gummed up). It had been sitting unused with gas in it for so long before I got my hands on it, for free.
I replaced the muffler ($6 shipped) today, because it was getting noisy (old one was rusted out). Sounds great now.
I actually started painting it today, engine shroud was rusting...so I tried the sandblaster out, cleaned that up, and painted it black. Next up is to paint the cast aluminum deck, toro apple red. The old paint is just flaking off.
73Delta88
 Posted: Thu May 04, 2006 8:07 pm |
The flagship... John Deere 430 lawn tractor. This pic is from a few years ago right after I painted it. It's about 22 years old and still going strong. 62" mid mount mower deck, rear PTO driven collection system with hydraulic dump, 3 cyl Yanmar Diesel, Hydrostatic transmission.
And the rest, in no particular order...
Stihl BG 85 leaf blower
Husqvarna 36 Chainsaw 16" bar
Ariens ST1136 11 hp snow blower (36")
Husqvarna 125R Brush cutter / trimmer
John Deere 14SB self propelled walk behind 21" mower
Troy-Bilt 4 hp Tiller / Edger
a really old Yard Man push mower
 Posted: Fri May 05, 2006 9:08 am |
Nice chrome cappies!!  Very nice indeed!
