It is currently Sun Nov 08, 2026 6:14 am
 Posted: Sat Jul 29, 2006 6:32 am |
Hi MysterHK, hello everyone,
Quote: I tried a small dab and I saw my paint was coming off on the rag ........
That's exactly what polish is supposed to do. What you have, is a "one step" polish/wax compound. They don't do either very well.
Here's a partial quote from meguiars.com: ........ As in polishing a diamond, the sole purpose of polishing is to create brilliant high gloss. ....... Waxing a car falls under the larger heading of protecting the paint finish from the elements by coating it with waxes, polymers, resins and silicones. .......
 Posted: Sat Jul 29, 2006 2:36 pm |
Good post Norm.
One other thing to add... If you have a dirty car, or oxidized paint, even a straight wax will come off with color on the rag. Its not because the wax is abrasive, its the rubbing of the rag on loose paint molecules.
 Posted: Mon Jul 31, 2006 11:39 am |
Your car should have a clear coat. There should be no paint coming off on the rag... should there? If your clear coat is somewhat faded, or very thin, its a possibility that you are actually polishing the paint underneath the clear coat.
If you have had the car painted since, then it may be a one step paint, with no clear coat, and you have nothing to worry about. Personally, I love the Meguiars Gold class wax, it doesnt last very long, but it shines better than anything else I have tried. Also turtle wax extreme shine works well.
