It is currently Sun Nov 08, 2026 2:36 am
 Page 1 of 2 [ 19 posts ]  Go to page 1, 2  Next
 Post subject: Tap and Die set...
PostPosted: Sun Sep 24, 2006 7:39 pm
Looking for a good quality metric/sae tap and die set. I've been eye balling the ratcheting gearwrench set, anyone else have it? Does anyone else make a ratcheting tap and die set?
 Post subject: Re: Tap and Die set...
PostPosted: Sun Sep 24, 2006 8:07 pm
Well, I'd still like to hear opinions...but I couldn't pass up this deal at Amazon.com
$162.99 + FREE SHIPPING
Special Offer: Use promotional code ALLTOOLS at checkout to get $25 back when you spend $150
Special Offer: For a limited time, get an instant 10% discount on any Hand Tool or Power Tool Accessory sold by Amazon.com.
I got $41.30 off the regular price, and the final price shipped was $121.69. Can't even beat that with my brothers NAPA discount...sells for over $200 there. Don't ask me how they do it, but if you're looking for a tap and die set...might want to take advantage of this deal. I love GearWrench/KD tools--innovative ideas make the job much easier.
PostPosted: Mon Sep 25, 2006 8:47 am
nice brando, tap & die set is very useful. What are you going to use it on first?
PostPosted: Mon Sep 25, 2006 11:41 am
engine block. :D
PostPosted: Tue Nov 07, 2006 5:45 pm
I just got it today....was on backorder for quite a while....looks great though. Very nice kit, includes metric/sae gauges...very handy. The adapters also work in my gearratchet set (Vortex sockets) if I needed a little more torque.
PostPosted: Tue Nov 07, 2006 7:33 pm
If you are going to use it on an engine block, is it to chase threads? If so, I would get a thread chaser instead. Taps can remove material, making the threads weaker.
Good buy on the TD set. I think my Snap-On was 220 for standard, the same for metric.
PostPosted: Wed Nov 08, 2006 6:16 pm
You have a link to thread chasers? I found a universal thread chaser...outside, for bolt threads. Nothing for inside threads though (except for spark plug chasers)....they just look like taps? I searched thread chaser and came up with tap and die set....
Wow...$440 for a complete tap and die set? how many pieces total?
PostPosted: Wed Nov 08, 2006 6:23 pm
I found this....
Don't know if those are proper sizes for my block...
EDIT: according to NAPA the head bolts are 7/16"-14 so I guess it would work.
Is this really worth it? That's almost the price of my entire 75 piece tap and die set :shock:
PostPosted: Wed Nov 08, 2006 7:21 pm
Heres the links for both my tap and die sets, and for a thread chaser... Both standard and metric
http://buy1.snapon.com/catalog/item.asp ... ir=catalog
Thats the TD sets.... heres a thread chaser
And this is what I use to chase threads...
Its actually a "thread restorer", but it doesnt take out any material, so thats what I like about it.
PostPosted: Wed Nov 08, 2006 7:23 pm
Also, ARP and NAPA carry thread chasers of a different style-
Thread chasers are worth it IMO. You wouldnt want a head bolt pulling the threads out of the block.
The purpose, as you know, is to clean the threads, not to alter them.
PostPosted: Wed Nov 08, 2006 7:37 pm
The SAE part of that snap on kit looks exactly like the Summit pieces...
PostPosted: Wed Nov 08, 2006 8:09 pm
Of what? The thread chaser, or the Tap and Die? The tap and die is different from what I have seen...
The thread chaser could very well be the same, but if you break it, they dont warranty it.
PostPosted: Thu Nov 09, 2006 2:42 pm
My T & D set is by Irwin/Hanson.
NC and NF only, up to ½", plus one ⅛" NP tap. I acquired my other NPs as I needed them. Haven't yet, had any reason to use anything metric.
I have never used anything but a used tap, or die, to chase threads. My bottoming taps were made by grinding the taper off them.
Brando wrote:
........ I've been eye balling the ratcheting gearwrench set ........
Why?
........ You wouldn't want a head bolt pulling the threads out of the block.
How would threads be altered by using the same tool that originally cut them?
PostPosted: Fri Nov 10, 2006 6:44 am
I wish I could remember where I read it, but a tap can actually remove material, since it is a cutter. Its not going to remove alot, but it could remove enough. A used tap isnt so much of a problem, b/c it has been worn some, and wouldnt be as likely to remove material in a pre existing hole.
A tool designed to cut threads is alot different than a tool designed to clean/chase them.
Ive experienced this too, by chasing some head bolt holes on a single cylinder briggs and stratton, and then attempting to torque the head. The threads pulled out before proper torque was achieved...
PostPosted: Sat Nov 11, 2006 4:26 am
I wish I could remember where I read it, but a tap can actually remove material, since it is a cutter ........
Doesn't matter, I agree it can.
"Can" is not the same as "does" or "will". The more experienced the user, the less chance it will happen.
........ Its not going to remove a lot, but it could remove enough ........
If it was not properly used, that same tap could have produced the same result during the original cut.
It would take an unusual obstruction to cause it to go off track. The user should "feel" the difference and know there is a problem, before the damage has started.
........ A used tap isn't so much of a problem, b/c it has been worn some, and wouldn't be as likely to remove material in a pre existing hole ........
Not much difference. Both are capable of the same damage when improperly used.
........ A tool designed to cut threads is a lot different than a tool designed to clean/chase them ........
And it does a better job at both.
........ then attempting to torque the head. The threads pulled out before proper torque was achieved...
Was it the tap's fault?
