raskull wrote:
........ " torque wins races and horsepower is for speed" ........
Usually used to "put down" a ”poser”, who is talking the talk (HP numbers), instead walking the walk (putting his POS on the line).
Whether it actually applies to any situation, depends what kind of racing is being discussed. Land Speed (power) and Drag Racing (torque) would only be two instances.
........ what kind of power/torque are you looking at when you see a cars front end come up on a drag strip? ........
How far is up? Fronts of 4.5 second Top Fuelers hardly go up at all.
Wheel stands are a different story. The car and the class (particularly tire width restrictions) its competing in, determines how the car/chassis combo is set up. Takes power to pull wheels. Power that could be used to move the car forward, instead of up. In some cases, the traction gain from the weight increase on the tires, is well worth the tradeoff.
All else being equal, it would take less power to lift a light front end.
........ What is the difference between horsepower and torque? ........
Picture a “torque wrench” on the bolt that holds the front pulley on your crankshaft. If you used it to turn the crank, the dial would tell you how much torque you are applying to it. Now, if you held it in place, and the engine turned by itself, the dial would tell you how much torque the engine was making.
I'm still working on an analogy for the HP part, cause you can't measure it that way.
........ what kind of configurations would give you high torque and low hp or vice versa. ........
Simplest example: Bigger bore/smaller stroke (over square) = more HP, and bigger stroke/smaller bore (under square) = More torque.
........ does anyone have a rocket 455? ........
All four of mine (one 461 and three 468s) were/are "regular" 455s. I don't know anything about “rockets”.
........ theres something about 7.5L ........
Mine were/are all 455s. I don't know anything about 7.5L.
91buickman wrote:
Baechtel's articles are always informative. He is a well known author of "how to" books for Chevrolet enthusiasts, and a long time contributor to the various Car(maro) Magazines.
In this case, there is not much that actually relates to raskull's questions.
