It is currently Thu Apr 18, 2024 12:38 pm
Author |
Posted: Tue Feb 05, 2008 3:10 am |
TOC Member |
We have not yet addressed that shiny throttle body, yet.
From the same 3800pro.com thread that was referenced here.
on 3800pro.com, "jeep45238 wrote: SUPER_GTP wrote: ........ Does it cut down that much on air flow resistance. ........ Not quite so true. Ever wonder why golf balls are dimpled? It lets them fly farther, faster, straighter. When the air stream encounters a little imperfection, like the fine machining marks left behind after boring out the housing, it creates little eddies, like what you see in white water rapids. This is happening to some extent down the entire length of the bore. Sound bad? It's not, it's actually good. This turbulence is very very very small, and doesn't even extend a 1/16th of an inch into the main 'mass' of air flowing down the tube. What this small amount of turbulence does is keep the main portion of the airflow from contacting the housing, and helps keep the velocity up. Those little eddies help your engine ingest more cfm's of air, which means more cfm's of oxygen. Yes, extrude polishing and having a mirror finish can help on the intake stream - when you're at very high rpm's constantly (a.k.a. nascar). Street - it's really not worth the gains that you 'may' have gotten, and from polishing the interior of the TB you'll never get a single horse or foot pound to show up on the dyno. Boring and polishing, maybe - but not polishing alone, especially not on a street vehicle.
And the "golf ball" thing?
It also applies to the rest of the intake system.
Posted: Tue Feb 05, 2008 4:24 am |
TOC Member |
91buickman wrote: ........ they are purley functional ........ We can see that. http://www.3800pro.com/forum/naturally- ... g-etc.html91buickman wrote: ........ doubt what you want ........ You have yet, to give any of us, the smallest reason to believe anything you say. 91buickman wrote: ........ neither of you queers ........ Grow up. 91buickman wrote: ........ has driven it ........ It would be a waste of time. 91buickman wrote: ........ so what you say based on your experience ........ Do you know what experience I have? 91buickman wrote: ........ 3800 FWD cars are prone to front and RR engine mount failure ........ More BS. You have a "problem" that no one else has. http://www.3800pro.com/forum/fwd-transa ... -help.html91buickman wrote: ........ taking a picture for your satisfaction is pointless in that matter ........ Yes, pointless. We have already seen your jury-rigged substitutes. 91buickman wrote: ........ How did the oil get, upwind, to the throttle valve? 91buickman wrote: ........ i dont knwhat youre talking about but ........ Yes, we know. 91buickman wrote: ........ in the engines i have tore down before ........ Yes, the many engines you have "tore" down. So many, that we can consider your anecdotal evidence, as scientific fact. 91buickman wrote: ........ this is always the case ........ And as always, we believe every word of it. 91buickman wrote: ........ my car is a daily driver ........ Congratulations. 91buickman wrote: ........ and it works....beautifully and has been for a long time now.
Except for a few little items?
http://www.3800pro.com/forum/fwd-transa ... axles.html
91parkave
Posted: Tue Feb 05, 2008 10:59 am |
TOC Member |
My car backfired and stalled becausse of a bad ICM module, not because of the MAF or injectors or anyother mod, but thank you for your assumptions.
As for my mounts it is a common problem with c-body cars 91-96, Most owners just tend to neglet them till they completley break.
as for the axle problem the strut wasnt pushed back into place before tightening it down, also the mount was completley trashed after i swaped in some newer struts problem was gone.
polished TB? yup its also bored out and polished and gutted, none of what jeep says applies to me and last time i checked jeep is not the automotive god of 3800pro or any forum. he has his beliefs othere people have theirs. but i guess all ported or polished TB's,superchargers,turbo's,Intake mani's, Cylinder heads must be a joke huh....
Posted: Tue Feb 05, 2008 11:16 am |
TOC Moderator |
91parkave wrote: polished TB? yup its also bored out and polished and gutted, none of what jeep says applies to me and last time i checked jeep is not the automotive god of 3800pro or any forum. he has his beliefs othere people have theirs. This isn't religion. Faith and belief don't make things work. Proof is in the pudding. However, you never have had any pudding, just assumptions that what you have done "increases air flow". No numbers, just the belief you helped it more than you hurt it. You are probably confused because it must take a lot of faith to drive your car with those modifications. Quote: but i guess all ported or polished TB's,superchargers,turbo's,Intake mani's, Cylinder heads must be a joke huh....
Nobody ever said it did.
Edited: :wink
Posted: Wed Feb 06, 2008 4:41 am |
TOC Member |
Here it is again:
88 Coupe wrote: 91buickman wrote: How did the oil get, upwind, to the throttle valve? ........
Posted: Wed Feb 06, 2008 1:43 pm |
TOC Moderator |
91parkave wrote: True, i do not have numbers Without them, we have no idea if these modifications helped, or not. 91parkave wrote: but i guess going from a 58mm, to a 65mm+TB dosent help my flow numbers at all. That depends on a number of variables, such as if your 65mm throttle body flows more air than the cylinder heads can handle in their stock form. When you eliminate a bottleneck somewhere, you create a bottle neck somewhere else. Flow numbers are pretty worthless if the components together can not process the air/fuel mix efficiently. When you enlarge the intake tract, you have to run more fuel to compensate. This can get difficult to correct when running the factory PCM. You run into similar situations with ignition timing. If the components don't work together, all a person would have accomplished is a car that is less reliable than it was before, with less "performance" to boot. This is rather difficult to explain, as there are many facets to how these things work together. 91parkave wrote: it could be in my head or "ass dyno" I am glad you can admit this. 91parkave wrote: can i borrow your machine so i can test my mod's to see?
Are you hitting on me? I don't have a chassis dyno, if that's what you are asking, but I am sure you could rent time on one for a reasonable sum of money.
Posted: Wed Feb 06, 2008 7:41 pm |
TOC Member |
91buickman wrote: ........ but thats the clear/brown stuff ........ Does not look clear, looks like glyptal. And it doesn't look anything like oil vapors from a PCV. 91buickman wrote: ........ which is like i was saying in the EGr thread ........ Nothing like you said, in the EGr thread. Here it is again: 88 Coupe wrote: 91buickman wrote: ........ otherwise all it does is build up carbone in your intake manifold ........ ........ If you had carbon buildup, in yours, you have other, unrelated, issues ........ Your childish diversion, did not answer the question. Here it is, again: 88 Coupe wrote: Here it is again: 88 Coupe wrote: 91buickman wrote: How did the oil get, upwind, to the throttle valve? ........
If you cannot answer it, just say so, and we can move on.
