It is currently Wed Aug 26, 2026 9:29 pm
86Delta
 Posted: Thu Mar 04, 2004 3:50 am |
what year is the truck? if the door handle on the inside unlocks the door as well as opens the door you can attempt this... try prying out the back top corner of the window frame, i have done this on cars but you have to be really careful. once you make a small gap (very small, just big enough to cleanly get a coat hanger in there) slip a coat hanger or other long rod with a loop on the end of it into the passenger compartment, try to get it on the door handle and pull. good luck.
 Posted: Thu Mar 04, 2004 9:29 am |
got power locks???  just hit the button with the coat hanger if so!
86Delta
 Posted: Thu Mar 04, 2004 1:32 pm |
have you ever tried to push a power lock button with a coat hanger before? it doesn't work out too well. sometimes if i need something more stiff than a coat hanger i use a length of 5/16 or 3/8 tubing.
 Posted: Thu Mar 04, 2004 6:19 pm |
dunno... Thats how I broke into my caddy once when I locked the keys in it (running nonetheless)... Coat hanger, positioned it perfectly against the switch, then gave it a little push... CLICK... most beautiful sound I had ever heard
I suppose though, some vehicles' switches are harder to push than others, and are in different places ...
 Posted: Fri Mar 05, 2004 10:04 am |
centimeters? are you one of those canadians or something?
 Posted: Mon Mar 08, 2004 10:21 am |
well... granted, some of them are stupid.. but I like our temperature system, and speed system
100 degrees = boiling
0 degrees = freezing
50km/h = city
100km/h = highway
very easy to remember
 Posted: Mon Mar 08, 2004 4:04 pm |
85cieraholiday wrote: Don't most cars have 2 sets of keys? My Olds does, same with my dad's Civic and his Harley motorcycle.
Yea...most "older" cars do...
The 1988 Ford Club Wagon has two keys, 1987 Delta 88 has two keys, 1981 Buick Regal Limited has two keys, but the 1998 Intrigue has only one key...due mainly because it has keyless entry...
85cieraholiday
 Posted: Mon Mar 08, 2004 4:11 pm |
Quote: Yea...most "older" cars do...
My dad's Civic is a 2000.
_________________ .
 Posted: Mon Mar 08, 2004 5:51 pm |
Well then, that's most likely why you have two keys then, one opens the door and one starts the car up...the theory is that you leave the ignition key in the car and only put the one key on the keychain that opens up the doors....that's what my olds manual says anyways...
