It is currently Thu Sep 24, 2026 6:00 am
Guest
 Posted: Thu Oct 16, 2003 9:50 pm |
I have an early 70's chevy tranny that complete down to the oil pan and it's painted orange. It has a shift kit also. It runs and shifts perfect. My friend gave it to me b/c he went in the Army and had no use for it anymore b/c he got rid of the Malibu he was going to put it in. It's sitting high and dry in my basement. It's a th350 as far as I know. Make offer as I just want ot get rid of it!
 Posted: Thu Oct 16, 2003 9:53 pm |
Hmm...I'll have to check this guest posting out because I thought I disabled it, but anywayz.....are you a member? If not, please register.
Now, you say the trans is a TH350, but I thought that trans is for Olds, Pontiac, and Buick.....and you said Chevy, so is it from a chevy or what? Please clarify, thanks.
strokercutlass
 Posted: Fri Oct 17, 2003 1:35 am |
| TOC Mechanic |
yeah Brando..whats up with that?  hehehehe...
the chevy tranny, UNLESS its a unibell ( which, most likely, isnt the case), will only fit the Chevrolet engines, and not the BOP engines
 Posted: Fri Oct 17, 2003 3:18 pm |
Yea, I forgot to set the permissions for this forum to no guest posting, since it was recently created...
No53Alero
 Posted: Fri Oct 17, 2003 6:14 pm |
Joined: Mon Jun 09, 2003 10:30 pm Posts: 156 Images: 42 Location: CINCINNATI, OH
sorry everybody that was me. I thought I was logged in already but I guess not! I have it sitting around and will take $25 for it I don't care. I thought that chevy's had th 350's and 400's but I guess everybody just calls them that.
_________________ One and Only Airbagged ciera!!
Final 500 Alero website
Primer Death
 Posted: Fri Oct 17, 2003 6:19 pm |
Joined: Sun Jun 08, 2003 4:11 pm Posts: 99 Images: 6 Location: Maine
strokercutlass wrote: yeah Brando..whats up with that?  hehehehe... the chevy tranny, UNLESS its a unibell ( which, most likely, isnt the case), will only fit the Chevrolet engines, and not the BOP engines
Or could get a conversion kit... for the bell housings...
Know which tranny is it that wines alot? it is found in 1990's Chevy vans
_________________ The Lead Sled has arrived!
