It is currently Mon Sep 21, 2026 1:47 am
PostPosted: Mon Oct 03, 2005 10:06 pm
'86 Cutlass Supreme, 307 4 bbl, TH200R4, power windows, bench seat, column shift, A/C, just turned over 100K, new exhaust, new rear shocks, new rear tires, solid AZ car with NO RUST on rear frame or underbody. White with blue interior.
Problems:
dented RF fender
few surface rust spots on trunk lid and rear quarters
vinyl top has been peeled off (previous owner)
will run, but needs motor (knocks and squeaks)
I bought this car to build as a driver for my daughter, but have since bought a '69 to fix up instead. It's an EXTREMELY solid car, without the usual frame rust. If needed, I'll even haul it to the shop to put it on a hoist so the undercarriage can be inspected. The previous owner had brought the car in religiously for oil changes and servicing....one day he called and said the engine started making noise after a trip...inspection found damaged lower end. I bought it with the intentions of dropping another motor in it, but you know how that goes....
Asking $600 but NO REASONABLE OFFER REFUSED!!!!!!!!!!!!!....I need to move this car ASAP to make room for the '69!!!!!!
email smghmg@mwt.net, or call my cell at 608-647-0061
PostPosted: Tue Oct 04, 2005 4:37 am
damn...you're fixing up a 69 cutlass for your daughter..... [Napoleon Dynamite] LUCKY! [/Napoleon Dynamite]
:lol:
