It is currently Wed Jun 24, 2026 8:50 pm
oldcars
 Posted: Mon Aug 28, 2006 11:59 pm |
Joined: Mon Aug 28, 2006 11:42 pm Posts: 8 Location: Quincy, IL
I have the following 1941 thru 1968 Oldsmobiles for sale:
1941 2DR SEDAN $3,200
1955 88 2DR SEDAN $1,100
1957 J-2 TRI-POWER MANIFOLD & CARBS $750
1960 DYNAMIC 88 BUBBLETOP $2,700
1964 STARFIRE 2DR HT $3,700
1967 CUTLASS 2DR HT $2,350
1968 CUTLASS 2DR HT $1,900
Complete details and delivery are available by emailing me at collectorcarsandparts@yahoo.com Delivery is available.
 Posted: Tue Aug 29, 2006 12:48 am |
oldcars wrote: ........ 1957 J-2 TRI-POWER ........ collectorcarsandparts@yahoo.com ........
Seems like someone with those handles would know the difference between a J2 and a Tri Power.
 Posted: Tue Aug 29, 2006 8:23 pm |
oldcars wrote: ........ You must have been looking in the mirror when you mentioned "BEWARE OF THE CLOWNS"
The clowns referenced in my sig are identified by their BS posts. Posts such as your first. They further ID themselves by resorting to using insults in place of any actual discussion of the topic. Kinda like, in your second post. Usually because they don't have a clue WTF they are talking about in the first place.
Now, did your name calling make my comment any less valid?
 Posted: Tue Aug 29, 2006 11:38 pm |
Not a game.
Actually, I'm quite proud that I can point out some mistakes and misconceptions before they become "urban legends"
Speaking of mistakes, would you care to address the J2 vs Tri Power issue?
 Posted: Tue Aug 29, 2006 11:52 pm |
oldcars wrote: Play your games, I don't care. Too bad that you don't have anything else better to do than welcome new members such as me into the forum in such a dispecable way. You should be so proud of yourself.
oldcars You should be proud you still dont get what Norm is saying. From 442.com, here are some differences between a J2 and a Tri-power intake. both are 3 2bbl carbs, but they ARE different. 442.com wrote: The thermostat on the 1966 L-69 3x2 Tri-power manifold is further forward than on other Olds V-8s, due to the need to clear the front carb, and thus uses a unique molded bypass hose for this application. It also uses a pair of roughly square covers, one on either side of the center carb, bolted to the top of the exhaust crossover passageway. Each cap should have four bolt holes, but only be held on with two bolts. These are the exhaust crossover blockoffs on the 1966 manifold. 442.com wrote: The J-2 intake fits 371cid blocks and 1957-58 heads ONLY. Have heard of it being adapted for similar applications, but Karl is reluctant to perform non-reversible operations on antiques.
The J-2 intake is a dual-plane intake that used a vacuum-actuated linkage. The center carb provided all idle and off-idle. At a centre carb throttle plate angle of something like 68' (degrees) the vacuum linkage would actuate, and open the end carbs, which operate at WOT only.
The linkage, if complete, is worth more than the bare intake, but probably not as much as a set of correct end carburetors. Not to mention air cleaners, or correct Air cleaner shroud (covered all three).
2GC uses an integral choke, while the 2GV uses a vacuum-break choke. The choke is actuated by a small diaphagm connected to steel tubing that disappears in the area of the exhaust manifold.
Not positive about functionality/routing of tubing.
The Original J-2 carbs are 2x2G (ends) and 2GC (center). These are, again, the small throttle plate variety.
Too bad I dont have anything better to do... The misinformation would keep moving from one mouth to the next.
We have the heat, we have humidity, we have the bullshit... now where are the mushrooms?
 Posted: Tue Aug 29, 2006 11:54 pm |
So we all understand it:
You post a piece of BS. I call you on it. You start name calling. You refuse to address the suject. You continue to name call.
And, I'm the bad guy.
I can live with that.
 Posted: Wed Aug 30, 2006 12:20 am |
Hi andrewk, hello everyone,
Sorry Grasshopper.
andrewk wrote: ........ From 442.com, here are some differences between a J2 and a Tri-power intake ........ 442.com wrote: The thermostat on the 1966 L-69 3x2 Tri-power manifold ........
This is one on those areas where, in addition to being redundant, 442.com has it wrong.
L-69 was a one year 3x2 carb setup used on the 400 only. Factory, literature, and dealers called it "Tri-Carb".
Still waiting for our new friend to stop running his mouth and start addressing the subject.
 Posted: Wed Aug 30, 2006 2:00 am |
88 Coupe wrote: Hi andrewk, hello everyone, Sorry Grasshopper. andrewk wrote: ........ From 442.com, here are some differences between a J2 and a Tri-power intake ........ 442.com wrote: The thermostat on the 1966 L-69 3x2 Tri-power manifold ........ This is one on those areas where, in addition to being redundant, 442.com has it wrong. L-69 was a one year 3x2 carb setup used on the 400 only. Factory, literature, and dealers called it "Tri-Carb". Still waiting for our new friend to stop running his mouth and start addressing the subject. Norm
Maybe someday I can be a cricket, and not just a grasshopper...
So then the 'tri power' so to speak, is a pontiac product, and not affiliated with olds?
Wasnt aware of this difference... thanks for clearing that one up!
Is 442.com correct about the J2?
 Posted: Wed Aug 30, 2006 3:29 am |
andrewk wrote: ........ the 'tri power' so to speak, is a pontiac product, and not affiliated with olds? ........ Tri Power is a Pontiac trademark. No other Divsion, or Manufacturer has ever used it. Quote: ........ Is 442.com correct about the J2?
I'll keep it simple. As far as I know, yes.
Olaf
 Posted: Wed Aug 30, 2006 7:47 am |
Quote: At a centre carb throttle plate angle of something like 68' (degrees) the vacuum linkage would actuate, and open the end carbs, which operate at WOT only.
...man, what's it like to stomp the throttle on a setup like that? Ba- WAAHH
