It is currently Mon Nov 16, 2026 12:06 am
 Page 2 of 2 [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Mon Apr 11, 2005 9:24 pm
Too bad you didn't get the 75x4 + 1100x1 memphis belle.... :twisted: :lol:
PostPosted: Tue Apr 12, 2005 11:20 pm
Ok...lemme break this all down for ya :lol:
From the deck, the RCA's pass thru the DS/VU (crossovers weren't used, basically used as an output meter), then to the Alpine 7 band parametric EQ (preamp signal processor..7 channels of equalization per channel to fine tune frequencies before going further down the line..worked much better than a simple active crossover network or bass/treble control, I'm more of an SQ person than an SPL person and I set it up as such).....then out of the parametric to an MTX 3 way active crossover network split to front/rear/subs. The front channels run to the KAC-723, then onto older 6 1/2" Alpine components (soon to be replaced by Infinity Kappas) with the tweeters aimed from the back of the rearview mirror off the glass to improve front staging). The rear crossover channels run to the KAC-823, then to 5 1/4" MTX components on prefab plate setups built for a Nissan pickup in the rear sides. The sub crossover channels run out to the MA Audio Bass Driver (similar to an AudioControl Epicenter, remote bass level adjust, phase, frequency range up front, as well as tuning adjustments on the module to enhance bass frequency ranges), then onto the Pioneer amp bridged mono at 4 ohms running the SPL 15's in series parallel for a 4 ohm load. The amps are all set at full range, and not crossed over internally....
I bought the Memphis Belle for $269.51 used off EvilBay, and yeah I would have liked to get the 1300D, but it wasn't in the budget, and a 400 watt 1 ohm mono load should drive the 15's juuuust fine :wink:
Thing I like about the Memphis Belle is that it's a 4 channel class A/B amp at 55x4 RMS, and a 400x1 RMS at 1 ohm class D amp, all built into one with crossovers and etc. It'll take up 1/4 the space, lose 3/4 of the wiring mess, and do the same thing as all the other stuff.....
I mean realistically speaking....how many RMS watts do you REALLY think that Pioneer 760 2 channel class A or B amp is running on a 4 ohm mono load....
compared to the Memphis running 400x1 RMS on a 1 ohm mono load, and being a class D to boot? I KNOW it can't sound any worse than the Pioneer, and that Wal Mart Pioneer amp pounds those DVC 15's pretty nicely to be honest, especially in a tank like the Vista! :lol:
Also will be redesigning the box for the 15's and going away from the power sucking sealed box to a larger redesigned slot port box, which by the figures will end up being in the 3-4 cubic feet PER SPEAKER range....good thing it's a wagon! :P The box now was built for the subs, but was designed to fit a smaller car, so the specs are on the narrow end of the line.......room is NOT a problem now!!! MUAAAAHAHAHAHAHA!!! :twisted:
