It is currently Wed Nov 11, 2026 6:08 pm
 Page 2 of 2 [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Mono or dual??
PostPosted: Thu Sep 21, 2006 7:43 am
Brando wrote:
........ surprise...you burnt the voice coil/s out by clipping it.
Thanks. Seems I missed the answer when I clipped (no pun intended) it out of the quote?
Ilovemy98 wrote:
........ When an amplifier clips, it dumps current straight to the speakers that are hooked up, and damage can happen in seconds ........
PostPosted: Thu Sep 21, 2006 7:53 am
Brando wrote:
You can destroy a sub by underpowering it, it's the user that destroys the sub.
Brando, Looks like your keyboard might have a problem. I corrected your typo.
:wink:
PostPosted: Thu Sep 21, 2006 8:15 am
73Delta88 wrote:
........ I corrected your typo.
Good catch.
PostPosted: Thu Sep 21, 2006 8:48 am
Thanks 73...I was in a hurry to get to class, BIG Abnormal Psych test...lol, done in 15 minutes. Yea, I see you quoted USER lower case...but you seem to have missed the actual typo... :lol:
You can't destroy a sub simply by underpowering it, it's the USER that destroys the sub.
Now it is correct.
For more detail, check this link out: Too Little Power Blowing Speakers
PostPosted: Thu Sep 21, 2006 9:46 am
Images: 5
Brando hit it right on the head with the last link he posted. That's what I meant, but not what I wrote. Whoops! Yes, technically it is the user that kills his/her speakers from trying to get too power from his/her amp or deck and clipping it out. That is actually the link I was looking for when I posted, but apparently I didn't look hard enough! Thanks for all the positive comments! I'm really enjoying having a place where I can talk and learn about all this stuff and not bore the crap out of people. My roommates don't want to hear about it!
-Carl
I miss the 98... but I'm loving the Regal!
PostPosted: Thu Sep 21, 2006 9:57 am
87Delta wrote:
........ an alternator power wire of about 10AWG ........
Is that what they used in the '88 G body?
My 1987 H-Body has 10 AWG from the alternator, it was just a guestimate figuring it might be the same. From factory they really aren't that big since they didn't need to push 125+ amps of power for stereo equipment, or any other equipment for that matter. I'm not even sure if the alternator on those cars are bigger then 110amp.
87Delta wrote:
........ bigger then 2AWG can be used if you are really pulling some power .........
From the alternator to the battery?
Yes, I had a 400 watt amp that drew less then 40 amps, I still got dimming from the stock factory 10AWG wire. It couldn't supply the power needed. I temporarily (temporary system, wasn't keeping it) hooked up some 2AWG from the alternator to the battery, and my dimming problem was gone. Although, from what I'm reading on Grave Reaper’s case, there is going to be more power (~145amps) then what the factory alternator can supply, so there we be a good amount of light dimming. Only way to correct that is a high output alternator.
PostPosted: Thu Sep 21, 2006 11:15 am
87Delta wrote:
........ it was just a guestimate figuring it might be the same ........
That was my point.
87Delta wrote:
........ Only way to correct that is a high output alternator.
Yes, one that has a terminal to match that larger wire.
PostPosted: Thu Sep 21, 2006 12:30 pm
87Delta wrote:
I believe so. Or something right in that range. The 88 G Body should still have the Delco 10/12 SI with an internal regulator. Not that the alternator necessarily matters, but the harness is the same for most of that line. The red wire should either be 12, or 10 AWG wire, at least thats what my g-body was. But it was an 84.
I cant say for sure, but I know it is pretty good sized wire for the application. However, I dont think it is big enough for a big stereo system.
