Brando, heres a little "old school" trick for figuring out front or rear speaker placement(more specifically components). Get yourself a quart ice cream container or a small bowl ( If this means going out and binging on a quart of Tom and Jerry or Chunky Monkey, so be it...think of it as supplying nourishment for the cause
) Sit your midrange in the bowl and move it to different positions, as you said. This way you can get the full effect of the speaker, as one way or another it will be somewhat enclosed, to properly display the midbass range and pitch...Then install them which ever way you choose
