It is currently Fri Nov 06, 2026 5:26 am
 Page 4 of 5 [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Sep 07, 2007 9:26 am
91parkave wrote:
Measurements, yes for the Top engine mount i installed, as the c-body cars do not come with them from the factory, Wbody cras have stronger engine mount setups to keep the engine from moving as much, I took the top engine mount off a olds cutlass, willren said it would bend the rad support which is bullshit, which is where measurements came from. the nylon strap was like i said temporary to keeep the weight ff the back trans mount so i could replace it. Learn the facts before you talk your shit
I think what's scarier is the JB weld holding the two pieces of angle together-
Why did it take you months to change the trans mount?
PostPosted: Fri Sep 07, 2007 10:29 am
BTW, what is holding your battery down? Looks like you are asking for trouble if you ever get in an accident-
PostPosted: Fri Sep 07, 2007 12:47 pm
Its 2 pieces of angle iron welded together i seriously doubt JB weld would hold that together.
uh it only took me about 20minutes to change my mount, what are you talking about?
I have the j hook setup which wasnt pictured, thats sort of a "mock up" at the moment. I had to see how far my cables had to be run etc.... The pic was the in between phases.
PostPosted: Fri Sep 07, 2007 1:27 pm
Maybe its just me, but I don't see any heat marks (bluing, etc) that are consistent with a butt-weld like that. Most welds you see that aren't finished (IE painting, etc) have a clear line of apparent heat concentration from the intense heat of the welding process. The weld looks darker than the angle, which led me to believe it was a cold weld material, like JB weld.
91parkave on Bonneville Club wrote:
........ ive kept measurements of the radiator support over the months even after hard driving there is no change in measurments so the rad support has not bent in anyway ........
91parkave wrote:
........ it was a temporary mod ........
So if it was temporary, and you drove it this way "over the months", and you did it to take stress off of the mount to change it, I ask again, why did it take you months to do it? Now especially since it takes 20 minutes.
I probably would have considered a box, but if its secure, that will matter the most.
PostPosted: Fri Sep 07, 2007 2:12 pm
Depending on the gauge of the metal and other varibles, yes bluing can occur but not always. If you dont believe its welded than zoom in on the picture if you think im lying.
Ok let me clarify:
The Nylon tie strap was reffered to as the "temporary mod" it was used to change my trans mount.
The engine mount was questioned by wilren on bonneville club because he said, the rad support was not strong enough and would bend under hard acceleration. Thats why i took before and after measurements and even to this day the rad support is strong and hasnt bent in anyway. Do you get the complete picture now?
PostPosted: Fri Sep 07, 2007 3:15 pm
91buickman wrote:
........ Learn the facts before you talk ........
Here it is again:
91buickman wrote:
........ that dosent hold my radiator in place ........
Read the following, again:
........ Your words, not mine.
You have been doing all the talking.
PostPosted: Fri Sep 07, 2007 3:28 pm
91parkave wrote:
........ If you dont believe its welded than zoom in on the picture if you think im lying ........
Why do you think any of us would make such an assumption?
Could it be, because you only posted a "during" image, not before and after examples along with it?
PostPosted: Fri Sep 07, 2007 3:31 pm
Maybe its just me ........
It's not.
PostPosted: Fri Sep 07, 2007 3:39 pm
91parkave wrote:
........ I have the j hook setup which wasnt pictured ........
Why did you post your hack job, instead of what you actually have?
PostPosted: Fri Sep 07, 2007 4:06 pm
Norm you posted the pictures of the nylon strap/engine mount pics, not me, as for the trunk pic- it was for the refrence of the radio antenna, and not for the battery setup i have.
PostPosted: Fri Sep 07, 2007 5:00 pm
91buickman: We can see why you do not like to post quotes along with your sources.
If you did, you would be unable to change the statements to fit your replies.
Everyone: Please excuse my rude use of fonts in the following response.
91buickman wrote:
........ The engine mount was questioned by wilren on bonneville club ........
As you well know, he did not question anything He was trying to deal with your BS/off topic comments, while maintaining the integrity of the thread.
91buickman wrote:
........ Do you get the complete picture now?
I already had it. I was there at the time.
Here it is again:
http://www.bonnevilleclub.com/forum/vie ... hp?t=78399
Again: Your words not mine.
PostPosted: Fri Sep 07, 2007 5:36 pm
91buickman wrote:
you posted the pictures of the nylon strap/engine mount pics, not me ........
It came from your post, not mine.
91buickman wrote:
........ it was for the refrence of the radio antenna, and not for the battery setup i have.
Everyone already knew that. You are arguing with yourself.
Here it is again:
As a side note: This could also apply to any other image you posted.
PostPosted: Fri Sep 07, 2007 6:01 pm
Looking at the initial post and a few replies... why was the door problem involved in an antenna post? Sorta lost at that point.
PostPosted: Fri Sep 07, 2007 6:03 pm
I dont post quotes because at the moment if i dont feel like it i wont, its that simple
Arent you the same one who was saying the use of large bold words was childish etc... yea you are the one who said that.
First off thread inegrity is something you wouldnt know about obviously. second willren deleted my posts and sent me quite a bit of PM's which obviously you wouldve never saw which is why your simple mind would think what you think.
No dumb&dumber you werent in my PM inbox, nor were you there when i posted and willren deleted, he also openly admitted to me that he was wrong for doing so only because i didnt take his shit, so he threw a fit and had it out for me, its that simple.
dumb&dumber wrote:
Here it is again:
Caveman
No not all my words ,some of them yes but not all of them.
PostPosted: Fri Sep 07, 2007 6:05 pm
That would be my fault but it dosent mask the whole thread. wait till you get to the part about the nylon engine straps, it gets even better :wink:
