It is currently Sat Nov 14, 2026 10:46 pm
 Page 1 of 1 [ 9 posts ]
PostPosted: Fri Feb 25, 2005 12:21 pm
Images: 12
Does anyone know where I can get some sort of wireing diagram so I can hook up my new Sony cd player in my olds??
Thanks
PostPosted: Fri Feb 25, 2005 12:24 pm
http://www.carstereohelp.com/stereoremo ... sCiera.htm
http://www.the12volt.com/installbay/det ... ype=Stereo
PostPosted: Fri Feb 25, 2005 12:47 pm
Images: 12
SWEET!!
Thanks Brando :)
PostPosted: Sat Feb 26, 2005 7:35 pm
Images: 12
Okay,
Brando those website helped me out HUGE!!
Cant thank you enough.
But now I have a dilemma.
I hooked my my new Cd player in my car today and iam all excited cause I have a cd player rather than the stock 87 tape deck.
So i went cruising tonite and it started to get dark out and i had the tunes cranked, and i turned on my headlights and my left signal stays on,
it doesnt blink it just sits there all bright and green and now when my high beam headlights are on the little blue signal light that tells me that my highs are on shuts off and when i shut the high beams off, then the little blue signal light turns on,
so its all arse backwards.
also half of my speedometer lights dont turn on, and half does, and when I put my four way hazzard lights on then the little blue high beam signal flashes, my both signals flash but not like they used to, they flash at opposite times than eachother and my speedometer lights on the left side that dont turn on no more flash with the hazzards also.
Does anyone know whats up??
Its like a friggin dance club in my car now.
PostPosted: Sun Feb 27, 2005 12:18 am
Well, I'm glad that stuff helped....as for the weird stuff that's going on... :?
So you had to take the instrument panel off right? Something must of have gotten switched around or something. Nothing in the stereo harness could have made it do that. Only thing I can suggest is go back and make sure everything is right like it was before.
PostPosted: Fri Mar 04, 2005 8:49 am
Images: 12
Okay, well I got my wiring problem fixed.
All I did was hit i huge pot hole downtown and now eveything is back to normal. lol
(seriously)
PostPosted: Fri Mar 04, 2005 6:08 pm
you hit the pot hole, and now everything is fixed? I'd say thats a sign that something is not so good... :-)
PostPosted: Fri Mar 04, 2005 6:30 pm
That's a sign of a loose ground my friend....you disconnected a ground when taking apart the dash.
PostPosted: Fri Mar 04, 2005 11:44 pm
Images: 12
That sucks!!
Taking apart that dash is a pain in the arse.
