It is currently Fri Nov 06, 2026 8:10 am
 Page 1 of 1 [ 6 posts ]
 Post subject: Wiring?
PostPosted: Tue Dec 05, 2006 3:41 am
I just bougt a 1988 Delta today for 500.00 This might just be temporary, I plan on using the car a as winter beater, but I actually do like the beast. However, I took am having a problem with the wiring for the stereo. The stereo is a Kenwood Excelon. I wired the Constant and the 12V together, Afrter I had everything wired (I thought) there was 4 grey wires left over, and then when I turned the key, The stereo came on for a few seconds, and then shut off. I turned it back on and same thing, it stayed on for a few seconds, then shut off again. What am I doing wrong? The factory worked fine.
 Post subject: Re: Wiring?
PostPosted: Tue Dec 05, 2006 9:19 am
Thanks to my mistake a while back of not using a wiring kit and spliced everything, I got ahold of a wiring diagram thanks to Brando. Here is the power side of it to get you started:
Constant 12V+ - Orange
Switched 12V+ - Yellow
Ground - Black
Illumination - Gray
Dimmer - Brown
Antenna Trigger - Pink
Antenna - Right Front
Now, if you're still having problems, then it might be something else wrong. Most head-units don't use the illumination or dimmer wires, you can just cut them off and tape them.
PostPosted: Tue Dec 05, 2006 10:46 am
Say what?
Everyone I've used so far does (have an illumination wire)... :lol:
Except for the older el cheapo Aiwa.
What is the model number on the Kenwood? Is it brand new? Did you have it installed in a previous car and functioning ok?
PostPosted: Tue Dec 05, 2006 7:46 pm
Brando wrote:
Say what?
Yes, the stereo was in my Saturn SL2 and it worked fine then. Last night I started thinking though, my brother took the dash out for me and disconnected all of the wires. And I I cut all of the wires, and remebered cutting the wires for the cigarette lighter...I was using wires from that to wire the stereo. IO bought a wire harness tonight, but I want to try getting around usoing it now that I thought of what the problem is... :blowup:
PostPosted: Tue Dec 05, 2006 8:00 pm
it doesn't sound like a wiring problem to me....
PostPosted: Tue Dec 05, 2006 11:40 pm
the problem turned out to be with the right rear speaker. The wires were touching, causing the stereo to over-load and go into protection mode. Got it working, but I ddint feel like dealing with the speakers tonight, so I will get to that tomorrow. I have the Directed Extreams from my Saturn to try to fit in to the rear. I know it wont work, so I will head to the Stereo Shop tomorrow to get something to fit the Olds.
