hey guys, im having a problem with my amp. I think something internally might be wrong with it but maybe you know something that i dont. I have it hooked up to the battery, fuses are good, amp is grounded, and is getting power. All the fuses on the amp are good also. However, it just will not turn on. Theres no power switch on the amp or anything like that. Any one have any ideas? Thanks
_________________ 1979 h/o is a project
- RHS 350ci
- Hi-Performance Cam
- Holley 750 Double pumper
What's your setup? I've had a similar problem when I first started out in car audio. Turned out I blew the fuse on the remote wire of the head unit. Luckily it had a fuse...a lot of newer head units don't...so instead of blowing a fuse you blow out the remote output. It's recommended to fuse the wire.
