It is currently Sun Nov 22, 2026 12:12 pm
 Posted: Wed Jan 02, 2008 4:50 pm |
with fuzzy sound from the front speakers, and no sound output (assuming your amp turns on and off properly now), I would suspect something to be wrong with your head unit. Check all the settings for fade / balance and check if your unit has an option to turn on/off subwoofer/rca output.
 Posted: Wed Jan 02, 2008 6:16 pm |
Check the crossover settings for the subwoofer amplifier, you might have it set on high pass...if it is a class a/b amp that is.
Do you have a multimeter? Check the AC voltage output of the amplifier, see if it is putting any power out.
How are these tweeters installed?? They aren't wired in parallel with the 4x6s to the head unit, are they? That would present a 2 ohm load (if the tweeters are 4 ohm, and the 4x6s I assume are 4 ohm), head units cannot handle that, disconnect the tweeters immediately--might be too late already, if that's how it is configured.
