It is currently Mon Oct 26, 2026 4:19 am
 Post subject: radio won't come on
PostPosted: Fri Oct 10, 2008 9:23 pm
I bought a used 2000 alero, I had to put a new battery in and now the radio won't come on. The fuses are fine...help???!!!!
 Post subject: Re: radio won
PostPosted: Sat Jul 11, 2009 1:15 pm
Is it a stock radio?, check the fuses in the back of the radio its self. If this does not work make sure the batt is tight. Un secure connections can make it not work. Even if the connection is hard to move by hand it could still make it now work. When you took the old batt out how did you disconnect it? Also there are in line fuses did you check those?
I wanna go fast.
 Post subject: Re: radio won't come on
PostPosted: Sun Jul 12, 2009 7:21 am
Are you sure it isn't locked out ? My 88 had Theftlock, and when I removed the battery the radio went into Lock mode, had to get on the internet to find out how to get a new code for the radio.
Russ
Users browsing this forum: No registered users and 1 guest
