 Posted: Tue Mar 16, 2004 3:48 pm |
Ah...very familiar with this dash...
The top mid section, the part above the glove box and such (has "Oldsmobile" lettering on it and A/C vents) comes off first. There are four screws holding it in place near the top of it, right underneath the edge of the dash top. Remove those screws, and then you remove that panel. It helps to shift it all the way to the last gear, and you slide that rubber grommet around the steering column forward. Then it's pretty easy to remove that panel.
Now you need to remove the lower part of the dash to get rid of the radio. Removing the A/C vent section of the dash, you revealed about six screws I believe. Remove those screws. Open both front doors, you'll notice that there also is one screw on each side of the dash, remove those too. Now, look below and you'll also notice four screws holdiing the lower part of the dash in place. Remove those screws too, two on each side (passenger and driver). Now, you think you could just remove it, but not quite yet. You also need to remove the "plastic" screws from inside the glove box. There are about 5 of the plastic screws in there that hold the upper portion of the inside of the glove box in place (it's a black panel). Remove all 5 of these screws....you just unscrew them and you can pull them out...they're like an anchor type thing. Once you remove all five screws, pull the plastic black panel down inside the glove box. Now that all the screws are removed and the glove box won't get in the way of pulling the lower dash off.....pull it out. The whole lower dash should be off now, it may take a little maneuvering because of the glove box...I recommend you also take the glove box light bulb out of the socket so you don't run the battery down.
OK, so now you see the stock radio sitting there...four screws hold it in place...take the screws out, and pull the radio out, disconnect the antenna wire, the harness, and since you're installing an aftermarket radio, you'll most likely want to take those plastic adaptors that held the stock radio in place and use it on your aftermarket installation kit. Use an aftermarket to stock wiring harness...and put it all back together by following the directions backwards.
86Delta
 Posted: Tue Mar 16, 2004 6:35 pm |
you forgot one thing, unplug the harness going to the ashtray.
 Posted: Tue Mar 16, 2004 7:26 pm |
86Delta wrote: you forgot one thing, unplug the harness going to the ashtray.
Actually...I never unplug that....I just let it lie on the floor while I am installing stuff or messing around with something....
 Posted: Wed Mar 17, 2004 3:11 pm |
Secret? no secret. I put Zero guage in my car from front to trunk.
Take it from the battery, and route it around to the driver's side by the firewall. Find the rubber grommet, and pop it out, run your cable through, and then put some expanding foam or something in the hole to waterproof it. Thats what I did.
86Delta
 Posted: Wed Mar 17, 2004 8:03 pm |
i ran my 2 4 guage power wires through my firewall on the passengers side, i drilled new holes and put a grommet in, just take off the black plastic cover on the firewall on the passengers side, you'll find some clear metal to go through over there. as far as the 6.5's go, i have Infinity Kappa Perfect 6.5 components in my front doors but i had to make fiberglass pods to put them in. at one time i had 5.25's in the front doors just in the door panel, so that might be your best bet, i think 6.5's are too big to use without some kind of pod.
strokercutlass
 Posted: Thu Mar 18, 2004 12:26 am |
| TOC Mechanic |
I've also seen people adapt the door speaker pods offered on certain Pontiac Bonneville models with the higher end factory systems to Delta 88's and 98's..it didn't look too difficult,actually.
