It is currently Sun Oct 25, 2026 4:45 am
 Posted: Sun Oct 10, 2004 2:54 pm |
Hi 85cieraholiday, All
FWIW: "Help with radio interchange" would be a more appropriate title for this thread.
Quote: ..........Its the same model as mine.........
If you mean they are the the same cars with different badges, and the radios are the same models, it should fit perfectly.
 Posted: Sun Oct 10, 2004 6:37 pm |
I hope someone gives you an answer you can use.
Under the circumstances, I understand your reasoning and don't have any problem with it, however, the following might help in the future.
On a busy site, the person with the best answer (along with many others) might not open your message because it doesn't look like it pertains to his area of expertise.
A similar notice will be posted in the "read this before you post" sticky or in the FAQ section at the site.
IMO: On a small site like this, all members and visitors are likley to read all recent messages.
 Posted: Sun Oct 10, 2004 9:13 pm |
Hi 85cieraholiday, Brando, Hello All
Brando: Looking at your logic, I think its a good call.
 Posted: Tue Oct 12, 2004 5:58 pm |
85cieraholiday wrote: Well I lost that bid (wasnt home when it ended) so Im bidding on a 1996 Buick Century am/fm/cass.
okay...now that could be a problem...I believe they may have changed the harness style then.
