It is currently Wed Nov 18, 2026 6:51 am
 Page 3 of 7 [ 97 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Jul 19, 2004 8:29 pm
Images: 3
Well, right now the car is in the body shop (friends house). New 1/4's are on, floor boards are patched, rockers patched and now moving on to the wheel wells/trunk floor area.
We will be notching the rear frame rails 1" or so on both sides and widening the inner wheel wells so that I can run a larger wheel/tire combo (18x10's with 295 series rubber hopefully) without making it look redneck with the rear jacked up and the tires sticking out past the body.
I've ordered a few more pieces to finish out the door panel speaker pods and will be heading down to try wiring them up temporarily to see how everything works.
I will be running a pair of 4" MB Quart midranges, a pair of JL Audio 6.5" woofers, a pair of 1" JBL GTO series tweeters, and a pair of MB Quart 5.25" coxials in the door panels:
I think I will be using a JBL P80.2 amp for each door pod (160Wx1 bridged) although that may be too much and I'll have to step it down. Still undecided on the subs. I'll likely have to sell the box I built and build another one since we will moving the wheel wells in a bit. Not sure yet.
I also plan on spraying the interior with sound insulation from Cascade audio and then topping it with Peel&Seal roofing material, then a stock style jute padding.
I have a set of headers to install on the 455 but that probably won't happen for a while. Not sure.
Also plan on redoing the 3" exhaust system and doing away with the rear exit tailpipes and coming up with a side exit exhaust just in front of the rear tires along with a pair of electric exhaust cutouts.
But before anymore engine work I'll have to finish the interior. New carpet, reupholster the stock rear seat with dark blue vinyl, and have the Trans-AM front seats recovered in dark blue leather with white rocket logos stitched into the headrests.
Car is also going to be lowered in front and back. Performance lowering not ghetto lowering. ;)
Most likely going to take a while. :(
468/T-56/3.73
PostPosted: Mon Jul 19, 2004 8:39 pm
I like what your planning for the seats! When they get done, post a pic so I can see!
PostPosted: Mon Jul 19, 2004 8:48 pm
Definately sounds nice BBO, but I am wondering about the speaker setup...
So, your going to use two JBL 80.2 amps, bridged to each side. So, you would run one RCA cable from the head unit, and the for the left plug you would y-split that into the left JBL amp and the right plug you would get a y splitter for the right amp. Just telling ya that, you wouldn't need to run 2 RCAs...
Now, the speakers, does the tweeter, woofer...etc, do they have crossovers? Cause you're going to want to cut the highs off for the midbass, and the lows off for the tweeters...
So, they are all 4 ohm speakers I am guessing? So you're going to wire two pairs of speakers together in parallel and then wire the two pairs together in series for a 4 ohm load? Then do the same for the other side.
PostPosted: Mon Jul 19, 2004 8:49 pm
Oh yea, I have heard the Cascade audio spray stuff is really good stuff....I have actually heard people use Peal N Seal first, then spray the Cascade on top of the peal n seal to "seal" the peal n seal, so it doesn't even have a chance of falling off or coming undone.
PostPosted: Mon Jul 19, 2004 9:33 pm
Images: 3
That was suggested to me by the guy I bought the pods off of. I had inquired about whether or not he thought the P80 amp would work okay for powering both sides and he said one P80 would probably work for the 5.25" coaxials but that I would probably want something a little more powerful for the running the 1", 4" and 6.5". He mentioned using two P80's per side and bridging them.
Thanks for the RCA tip. Wasn't quite sure how I would do that and had thought of a Y splitter but didn't know if it was acceptable to use. I was actually drawing up a wiring diagram in AutoCAD so that I could better visualize everything. Once I finish I'll post it here and let everyone pick it apart.
I am running a 4ga power cable from the battery back to a distribution box where it will split that into (4) 8ga power wires for each amp. Still not quite sure where I will be grounding the amps.
Yes, he included 2 pairs of 12db octave crossovers. And as I understand it, you have the postive and negative speaker wire from the amp running to the + and - on the crossover and then from there the crossover has a +/- for the woofer, midbass, and a -6db, -3db, -0db and - for the tweeter that you connect the speaker wires from the respective speakers to.
And I believe the other set of crossovers is for the 5.25" coaxials as it has two different plugs on the speaker. One set for the woofer and the othe for the tweeter.
I'll try and finish up my wiring diagram this week and post it. It will be easier to see what I plan to setup than to try and explain it. That way we can discuss what is right or wrong about it.
Thanks,
468/T-56/3.73
PostPosted: Mon Jul 19, 2004 10:50 pm
Well, there would be a + and - connection for the tweeter output too. I see, so you'll have a 3-Way component system and coaxial speaker in each door. The -6db, -3db, and -0db for the tweeter is most likely a switch. My component set has a switch like it too, a little more settings, but it's attenuation for the tweeter. Like -6db would lessen the highs, so they don't sound to "bright" or "harsh". Once you get em' installed you'll hear what it does.
PostPosted: Thu Jul 22, 2004 11:42 am
1. sand down car DONE!
2. Body work DONE!
3 Paint and clear coat DONE!
4. Buff down whole car DONE!
5. paint headlight bezzles DONE!
6. Install Alpine head unit DONE!
7. Install JL 3.5" front speakers DONE!
8. Install Kicker 6X9's in rear DONE!
9. Install Kenwood W3000 12" subs DONE!
10. Install amp wiring kit DONE!
11. Install trunk neon DONE!
12. Install interior LED's DONE!
13. Buy 14" 100 spoke wire rims COMING SOON!
14. Purchase paint and install hood scoops DONE!
15. Purchase paint and install wing SHOULD BE HERE TOMORROW!
16.Purchase Paint and install roof scoop SHOULD BE HERE TOMORROW!
Only thing left on my list is engine work and considering my Cutlass Ciera is loaded with "The Duke" 4 tech 4 banger i dont have many options i have a thread opened about this and i am more than curious if anyone has any performance tips or advice for me drop me a line and let me know because anything will help thanks for listening to my self righteous rant. But hey i am pretty damn pleased with myself i have accomplished all this work in 2 weeks :)
We are the Aqua Teens make the homies say HO! and the girlies wanna scream Aqua Teen Hunger Force number on in the hood G
PostPosted: Tue Jul 27, 2004 12:29 am
install air ride
buy ssbc brake upgrade
buy billet steering wheel
next year completely redo the car fill all body lines and bumpers and 2 tone paint job with some graphics
PostPosted: Tue Jul 27, 2004 5:41 am
I have been restoring a 70 442 holiday coupe that I inherited from my dad in 81.
It will be coming back home from the paint shop again later today. It went back down for some final touchups.
The car has been in the state of restofication since the begining of the year.
My plan is to have it back on the road in a few more weeks.
John
Resurrection after 19 years in garage storage!
A Few Restofication Pictures
This was my father's Oldsmobile!
PostPosted: Thu Jul 29, 2004 7:29 pm
Well I can cross off the vaccum lines and the gas cap from my list, big improvement huh! lol
PostPosted: Wed Aug 04, 2004 9:09 pm
Well I can now cross regestration off my list as of this AM my car is a legal begal (I cant spell ya know). $131 for a 2 yr regist. Not to bad as tax on it was ....$6 lol.
PostPosted: Fri Aug 13, 2004 7:04 pm
Images: 42
I plan on installing a second battery in my trunk to kep up w/ my 2 and maybe more compressors in my trunk. I was told by a professional auto electric shop that specializes in high output altenators that those high output altenators only put out high amps when at a higher rpm which is when my 100 amp can keep up, I'm having trouble at stoplights w/ my lights on along w/ my compressors. Beyond that a paint job and maybe shaved door handles and moldings. I just installed the triple play bags in the rear an now my back bumper sits at least 3 ft off the ground fully raised and still slams muffler scraping low! New wheels probably 16's. that's enough for now!
Final 500 Alero website
PostPosted: Sat Aug 14, 2004 10:33 pm
well getting ready to install my new head unit, tv, ps2, 200 watt amp for the bass shakers, bass shakers, also saving up for new subs and very big amp. i hope i can afford it. the amp alone is about 600 bucks. well i will take some pic and let you all know when i get it done should be done by next sunday night. i still have to get everything together.
Rusty Froman
President and Founder of Simply Irresistible Car Club
http://sicc6.tripod.com
http://www.cardomain.com/memberpage/347561
PostPosted: Sat Aug 14, 2004 10:50 pm
600 bux eh?
What brand/wattage is it?
PostPosted: Sun Aug 15, 2004 10:05 am
click here to see the amp i want on ebay cause the company that makes it wants about 1400+ for it
Rusty Froman
