It is currently Fri Nov 13, 2026 8:07 am
85cieraholiday
 Posted: Wed Jun 01, 2005 6:42 pm |
How much has your car cost you so far? Heres a run down of mine, I got the har Jan. 1,2004 with 72,687 miles, currently June 1,2005 with 76,046miles.
Hub Cap Key-$17.28
Cat back exhaust-$133.00
Gas Cap-$7.42
Oil Change/Air Filter-$25.00
Upper+Lower Rad. hoses/Thermostat/coolent flush-$37.11
Valve Cover gasket+oilchange+new plugs-$29.76
Alternator/a/cbelt/powerster.belt/alt belt $304.72
Battery $80.64
Window Repait $99.64
New Radio-$20.33
Front brake pads/pass side caliper-$87.00
Low beam headlams-$15.00
New Front White Wall Tires-$160.06
Ignition Module-$249.24
Total $1,266.20 in 3,359 iles = aprox 38cents per mile in repair then u still need to add in 120 a month for gas and insurance. 8)
_________________ .
Joes 94 cutty
 Posted: Wed Jun 01, 2005 10:38 pm |
well.....
Fog Lights - $40.
Bra - $25
Hub caps - $20
Map Sensor - $35
Jensen Deck - $200
Lightning audio 6x9's - $60
Neon lights - $40
some spray paint - $15
thats about it for now.. so, a few hundred bux with all the tax...
-Joe.. ohh, and i bought the car for 500 bux.. dont know if thats included or what.
Rockford fosgate AMP 400 watt
Rockford fosgate Sub 400 watt
Pioneer 3 way 355 watt 6x9's
Pioneer Tweeters
Cobra C/B radio 44 watt
P/A speaker for good times
5 foot whip antenna
 Posted: Thu Jun 02, 2005 9:35 am |
thinking about it would just make me cry
seriously though, I have no clue how much my car has cost since I bought it. Likely something like this:
3800 - car
600 - wheels
1500 - tires, struts, alignments, etc
500 - sensors, misc parts here & there
300? - waxes, car washes, polisher etc...
400 - broken headlights, smashed up bumpers, trim & paint
700 - rough estimate of stereo equipment in car
200 - console computer and fm transmitter
8000 CDN... not including fuel. Yikes. Now you made me cry!!! Never though of it all that way before!
I've put 90,000 KM's on my car since I got it a few years ago. I drive A LOT.
Cutlass95Ciera
 Posted: Thu Jun 02, 2005 10:11 am |
well, lets see.
Car was free
200 on tires and an alignment and about the same on breaks.
I also need to fix a leaky manafold but I'll let my brother the mechanic handel that one
50 for a good old Meijer battery, gotta love the 10% discount
300 on my system
It had 63,000 i think when I got it and i just hit 90,000. Had it for 3 years now
Joes 94 cutty
 Posted: Thu Jun 02, 2005 10:47 pm |
i bought the car for 500 bux, from my mom.
-Joe
Pioneer Tweeters
5 foot whip antenna
bdyman
 Posted: Sat Jun 04, 2005 11:05 pm |
Joined: Wed May 19, 2004 2:16 pm Posts: 171 Images: 22 Location: chicago baby!!!!
lol........you don`t even want to know
_________________ how low can you go????........pssssssssttttttttt.....got air???
No53Alero
 Posted: Sun Jun 05, 2005 9:04 pm |
Joined: Mon Jun 09, 2003 10:30 pm Posts: 156 Images: 42 Location: CINCINNATI, OH
my new car
$1000 pioneer avh 5700dvd player
$800 rims
old lowrider
WAY TOO MUCH!!!!
front struts $560
back bags all 3 sets of them that i interchanged $500
4 total viair 450 compressor's $800
that's just the start, I had 3 totally different interiors in that car(blue panne crappy stuff!!, dark blue/black crushed velvet, blue swirl/black crushed velvet)
4 different sets of wheels(14" and 13" wires, lowenhart ld1, and alt racing)
international series body kit/paint $200
stereo system $1300
_________________ One and Only Airbagged ciera!!
Final 500 Alero website
Hans
 Posted: Mon Jun 06, 2005 4:42 pm |
16"s = free from LSS
Belt = $36
CAI + K&N = $80
High Flow Cat = $80
180* = $6
Silverstar Headlamps = $73
Oil+Filters = $27
Spark Plugs = $53
Plug Wires = $34
2 Rotors + Pads = $140
Not bad for nearly 15,000 miles in 8 months
BigBlockOlds
 Posted: Sat Jun 18, 2005 12:27 pm |
I'm guessing the price of a new car. By the time I'm done, it'll probably be the price of a new Z06 Corvette. LOL
468/T-56/3.73
Turbocharged400sbc
 Posted: Thu Jun 23, 2005 7:53 pm |
For the Twin engine 94 Oldsmobile 442 - son of the 66 Hurst "Hairy" Olds 442
94 Olds Cutlass supreme (bought used) loan/paid ~$5000
work/parts replaced on stock cutlass, front struts, brakes, 3100 gasket set (porting and polishing/backcut valves = ~ $400
full performance rebuild of 4T60E trans with my shift "kit" modifications, and 500 rpm higher stall convertor = $1800
total (so far): $7200
PLUS (to make it the 442)
90 toronado trofeo-free (well gas to haul it to Al's = 10$
welding gas/wire/steel/grinder wheels/plasma cutter consumables and other supplies = ~$300-400
JEGS, Aeromotive 450 lb hr 100 psi fuel pump and stainless braided lines and AN-8 and 6 fittings, alum hard line, 19 gal fuel cell = ~ $750
misc bolts, wires (have a couple barrels of TXL high grade wire from swapmeet-40$), switches, gauges etc. = ~ $75
14 ft Morse shifter cable (custom ends) = $100
custom made (4th generation) rear engine throttle cable = $35
two reman axles, and full gasket set for 3800 (from when we ported and polished etc) and trans filter/gasket = ~ $300
350 sbc radiator = free, hoses = free
new rear struts/brakes (for front of trofeo-installed in rear of 442) = $300
Flomaster 2 chamber muffler (for front engine-rear is open) and custom (by us) exhaust = $100
and the newest stuff...
JEGS 10 point CNC mandrel bent mild steel rollcage = $220
JEGS, pair of G-Force 5 point camlock racing harnesses SFI 16.1 = $200
JEGS, pair of G-force Graphix SA2000 racing helmets (he had to get one fer the wife-he wants her to give him head while she's wearing hers, lol) = $400
Total (for 442 conversion): ~ $2890 and maybe a bit more that i am forgetting so..... $3000
Whole project total (so far) = ~$10,200 for a car that's 0-70 mph is only .1 seconds slower than a 99 Corvette Hardtop at a WAY cheaper price-sleeper baby!!!!
I figure another 2-3 thousand for the Turbocharger/intercooler/plumbing, MegaSquirt DIY EFI, and SI and SII Hybrid project/parts for the rear engine......
should really wick-up the power!
Not bad fer a couple of rednecks....
Redneck Engine-uity LOL
James and Al
Psyco Diver 69
 Posted: Sat Jul 09, 2005 5:22 pm |
I'm a $2000 in the whole at this point I would say, the biggest hits I've taken were my new hood ($600), new tires ($450) and the new motor ($300), everything else was odds and ends.
_________________ Jake 19/m
1972 Olds Cutlass- Parts car
