It is currently Tue Nov 10, 2026 11:08 pm
c_creations
 Posted: Mon Jul 18, 2005 11:00 pm |
ok, what are your 1/4 times? Mine in my new 88 cutlass supreme is 15.61, but, that was with a stop watch in a rough 1/4mile, so give or take a few?
But what are yours. even if there like this one, you can get an "about".
Lets hear em!
CCC
 Posted: Fri Jul 22, 2005 9:40 am |
I would just look funny showing up at the track to test my 1/4 time... And I'd likely be over 20 seconds anyways
Hans
 Posted: Fri Jul 22, 2005 5:21 pm |
15.84 @ 88MPH (2.2 60') w/stock tires @ Boise Firebird Raceway 11/04
Turbocharged400sbc
 Posted: Fri Jul 22, 2005 5:46 pm |
94 Oldsmobile 442 with two V6 engines:
13.81 @ 98+ mph 1.9s 60' times (consistent-dontcha love 4 wheel drive!)
in 90+ degree weather at over 60% humidity!
on 01 GAGT rims with brand new street tires!
should have higher trap speeds but my guess is all the extra roatational inertia of the two transaxles/axles etc is slowing us down on the top end...but she is def a beast in the 1/8th mile!
Joes 94 cutty
 Posted: Thu Sep 08, 2005 8:27 pm |
im not sure what mine would run.... maybe ill give er a shot...
-Joe
Rockford fosgate AMP 400 watt
Rockford fosgate Sub 400 watt
Pioneer 3 way 355 watt 6x9's
Pioneer Tweeters
Cobra C/B radio 44 watt
P/A speaker for good times
5 foot whip antenna
c_creations
 Posted: Thu Sep 08, 2005 11:00 pm |
584olds wrote: Look on the window:
What is that number there for? is it to tell them what your best is of the day, or ever or what?
CCC
c_creations
 Posted: Thu Sep 08, 2005 11:01 pm |
Turbocharged400sbc wrote: 94 Oldsmobile 442 with two V6 engines: 13.81 @ 98+ mph 1.9s 60' times (consistent-dontcha love 4 wheel drive!) in 90+ degree weather at over 60% humidity!
wow
CCC
 Posted: Fri Sep 09, 2005 1:17 am |
Hi c_creations, hello everyone,
Quote: What is that number there for?
In Bracket (handicap) racing, the driver picks a time he thinks his car will run. It's called a dial-in and it's marked where the timing tower can see it and set the lights to reflect the difference between the two cars dial-ins. The car with the slower dial gets a head start. If both drivers get identical reaction times, and both run on their dial, they will tie. Since reaction times differ, and cars don't always run exactly on their dial, one car always wins. A red light, or too quick an ET (break out) is an automatic loss.
The number is his dial-in. He ran 10.80s on that day.
A lot more can be learned by visiting your local strip as a spectator.
Both my Coupes will run 11.90s (at sea level) using 92 unleaded. The 468 at 116 MPH and the 439 at 114.
strokercutlass
 Posted: Mon Oct 03, 2005 10:23 pm |
| TOC Mechanic |
12.4@ 111 with the '72 the first time out....haven't been back since, and had alot of things that needed changed or updated, but hopefully next year I'll be back at it......should be in the mid 11's fairly easily if everything works out and holds together.
Psyco Diver 69
 Posted: Sun Nov 20, 2005 8:14 pm |
14.6@93 2.1 60', probably could have gone faster if I had couple more runs. I need more traction and I should have messed with my carb and timing too, but not to shabby for a smog motor
_________________ Jake 19/m
1972 Olds Cutlass- Parts car
