It is currently Tue Nov 10, 2026 9:20 pm
73Delta88
 Posted: Tue Dec 02, 2003 7:56 pm |
Hey, I just test drove a pickup I'm thinking about buying... I know this is not the CHEVY Connection, but It's still in th GM family so I think it's close enough! Tell me what you guys think:
It's a Chevy Z71 short bed step side
1991
140,000 miles
350 V8
4X4
Automatic Transmission
Black paint (in o.k. condition... not GREAT but not bad either) some peeling on one edge of the hood, but I figure I can fix that to look acceptable easy enough.
the interior is fair, it has the wear you'd expect to see in a vehicle of it's age, but nothing major. no big rips or bad fading or bad smells or anything like that.
Completely brand new exhaust system (stock)
Pretty much rust free except for a small spot on the rear bumper
I drove it a little and it seems to run and shift just fine
the engine oil looks dirty, but no signs of water or anything like that
the ATF looks ok, and doesn't smell burnt or anything
The guy was asking $3,500.... I got him down to $3,000 but he doesn't want to go any lower.
I'm leaning towards buying it mostly because of my desperate need for a winter vehicle... plus I always wanted a truck to bang around in.
think it sounds like a good deal? or a little steep?
86Delta
 Posted: Tue Dec 02, 2003 9:06 pm |
$3000 sounds like a fair price to me. with the only rust being on the bumper sounds like a good deal. even if you have to put some money into it (like brakes and general maintenance items) i think it would be worth it.
Cutlass95Ciera
 Posted: Thu Dec 04, 2003 9:18 am |
It must be nice having another car to drive in the winter, I sure need to get one...hint hint to anyone selling a beater  Hope you have fun with your new truck
 Posted: Thu Dec 04, 2003 9:58 am |
i've got an 86 plymouth horizon you can buy!
 Posted: Fri Dec 05, 2003 1:11 pm |
well... i could have some pictures of it if you want... But it would be more expensive to get the thing to you than I would sell it for! I assume you are in the states, and it would be annoying with KM's instead of Miles but what ever, suggest a method of transportation and you can have the car for 500 CDN!!!
it runs awesome, but it has some small rust on the rocker panels and wheel wells. interior is very clean, but it will need a right front wheel bearing, because it humms when you drive over 40km/h... and tires very soon.
its a beater for sure, i dont mind keeping it around here for a backup vehicle, but if someone were to put 500 in my hand, they could have it. Thats like 400 us or something... damn currency rate.
73Delta88
 Posted: Fri Dec 12, 2003 8:54 pm |
yea.... so I may have gotten screwed over  the truck I bought looses oil like crazy, I havent been able to figure out where it's going. sunday I put 2 quarts in it to bring it up to full and today the level was below the dipstick.
no obvious leaks... no puddles under the truck
it's not burning it because it doesn't smoke AT ALL
just today I noticed that the coolant is taking on a brownish color.... must be going in there.
it starts and runs good, just seems to idle a little rough, I've been planning to really go through it next week after I'm done with finals (change all the fluids, some tune up parts, etc because I have no idea when the last time any of that was done) but this oil loss is a very bad sign. I'll probably just check the compression and go from there.
I've never heard of oil going into the coolant... I thought was usually the other way around if there was a crack or blown gastket, but now that I think about it I guess it's very possible. I'm having great luck with engines lately! ](./images/smilies/eusa_wall.gif)
86Delta
 Posted: Sat Dec 13, 2003 1:41 am |
i wouldn't put any money into tune up parts just yet before you figure out where that oil is going. does the truck have an oil cooler? it is possible that is cracked inside the radiator, i've seen it happen twice with trans coolers. is the coolant just brown, or is it slimy too? it could be a head gasket, although i agree, it is usually the other way around.
86Delta
 Posted: Sat Dec 13, 2003 5:42 pm |
not sure of a way to pressure test it and it is not exactly repairable, the entire radiator would need to be replaced. how is the rest of the radiator? if its clogged or maybe even seeping a little, this would be a good excuse to just replace the whole thing. maybe before that drain the coolant and use a chemical flush to clean it out a bit, then put in fresh coolant and see if it turns brown. i'd certainly count out the radiator before i go tearing down the engine to do head gaskets, although i have done head gaskets on an 89 chevy pickup, not a bad job. the tbi fuel injection has like 5 plugs and 2 vacume lines, that makes it alot easier.
strokercutlass
 Posted: Sat Dec 13, 2003 10:42 pm |
| TOC Mechanic |
73..pull the plugs and check them for deposits or funny coloring...also, it wouldn't hurt to do a compression check. It sounds to me like the oil cooler has cracked or has a separation in it. Another thing...is your coolant level rising? This would coincide with oil being pumped into the cooling system, thereby making the coolant level rise. A head gasket thats not completely blown could push oil into the cooling system and still run fairly decent, however, you should be able to tell if thats the case by the way it runs when you first start it in the morning. Cooling system pressure will rise after a warm engine is shut off, due to heat absorption, and the pressure will generally seep antifreeze into the cylinder closest to the spot thats leaking, causing a cold misfire until the engine either burns it out or warms up. The newer Chevy V-8's are also notorious for intake gasket water leakage, but will almost always push antifreeze out, either in one or the other front corner of the intake, or at the rear of the drivers side head. They won't normally leak oil into the cooling system there though, due to the fact that the water port level is higher than the oil level, and coolant system pressure is higher than the pressure of the oil thrown against the bottom of the intake. I'd take the time to do some diagnostics before I'd jump in head first....
86Delta
 Posted: Sun Dec 14, 2003 2:42 pm |
not sure about what pressure a compression check should turn up, the most important is that the cylinders are all showing pressure in the same ballpark. but i don't really see what a compression check will accomplish though, because it is a oil into coolant problem, not a combustion chamber into coolant problem. signs of combustion chamber to coolant leaks would be if the system builds alot of pressure shortly after startup and if the coolant is dark. one way i have diagnosed this is to drain the system, run the engine with the radiator cap or the thermostat housing off and check for combustion gases coming out with the tailpipe probe from the inspection machine.
i agree with stroker, check to see if the coolant level is rising. another way to check, although i am not sure if there is enough oil in the cooling system for it to work, is to put leak detector dye (the kind you need a UV light to see) into the oil and see if the dye shows up in the coolant. even though this will not pinpoint where the oil is coming from, it will make certain that the oil is going into the coolant.
