It is currently Mon Nov 23, 2026 10:24 pm
 Page 1 of 1 [ 6 posts ]
PostPosted: Thu May 25, 2006 11:04 pm
Images: 8
Prior to sending my car to the shop to have the transmission fixed, I was going through the fuse panel and was carefully looking at the diagram that was affixed to the cover. According to the diagram, supposedly my car could accommodate a digital speedometer and fuel gauge. This would require 2 fuses to be placed in the #1 and #2 fuse sockets.
Hmmm..... If I wanted to put one in, my only dilemma would be to somehow advance the odometer to match the current mileage on my analog one. Thoughts anyone?
PostPosted: Fri May 26, 2006 9:12 am
This very well might be true. I took my instrument cluster out once, and noticed that even though it was analogue, the only connection was a massive electrical connector with at least 30 pins on it (digital-analogue guage? what an oxymoron). Maybe the digital one just plugs right back in?
Gotta be some info on it somewhere, because if this is the case, I would definately be interested also!
PostPosted: Fri May 26, 2006 2:10 pm
I'd like to know if this is possable as well. Though, I want to install the optional cluster with the guages. I hate not having a temp guage.
PostPosted: Sun May 28, 2006 6:33 pm
seem to remember a regency brougham in the junkyard with the three extra gages oil, voltage and temperature on the right side of the fuel gage. can investigate if you like.
and i beleive what they call that speedometer is electronic. same thing in my truck. just plug and play.
digital ones i don't know if they interchange or not, have often wanted to try but never found a digital one that wasn't broken.
that little computer on the dashboard where it says Eighty-Eight/Ninety-Eight tells you oil pressure and alll that as well.
but....... the engine sending units would need to be changed, because the sensors for lights [what you have??] are different from the ones that feed needles and I don't know if the plug has the same points. I tried to put a tach cluster in my 88 gmc and it didn't work, there was no feed. But anyway the sensors run on resistance and the level of resistance, or lack thereof moves your needle around, similar idea to a fuel sending unit, only different. Lights, the sensor reaches one of two points when it does, flicks on a light and a chime or whatever your car is set up to do.
I installed extra gages in my 84 Delta, they were great.
Al Melanson
"Complete Concrete"
1988 GMC Sierra SLE K2500 x cab/8' 5.7/700R4
1988 Oldsmobile Cutlass Supreme W 2.8/Auto
PostPosted: Sun May 28, 2006 6:54 pm
Tis ok, kinda like to see for myself. I'd like to see whats all involved anyways. ;)
Around next weekend or early to mid June or so I might being going to the junkyard to get some stuff. If anybody wants any pics of anything, just let me know in a PM. Isn't 100% though, so it will only be a list I'll make when I go.
PostPosted: Sun May 28, 2006 7:15 pm
just figured i'd offer since i'm always at the junkyard, pretty good connection, have spent hundreds of dollars there in the past years and can almost get anything for just about nothing now. but a complete pickup box for my 88 gmc for 100 bucks. no rust or dents even came with taillights and an under-the-rail bedliner.
Al Melanson
"Complete Concrete"
