It is currently Tue Nov 24, 2026 10:08 pm
 Page 1 of 1 [ 7 posts ]
PostPosted: Sat Jul 08, 2006 2:54 pm
I have a '89 nineteen-foot Oldsmobile Custom Cruiser boat (second generation of the Custom Cruiser, based on the 77-90 B-platform) and I want to tow a '89 nineteen-foot Renken Cabin Cruiser boat for my uncle, amusingly enough.
Right now the Olds has a little bar bolted to the frame somewhere, looks relatively light-duty. I know that it will need to be replaced with a proper 2" square tube hitch.
My question to you guys is - Do you think that the stock 307 with THM200-4R has the towing capacity to handle a large boat? The car weighs close to 4,500 pounds, and I don't know how much the boat weighs.
442.com says that the THM-200-4R is rated for vehicles up to 6,000 pounds. I don't know what the boat and trailer weigh, but I estimate it's more than 1,500 pounds. However, I was told that it didn't matter.
I've also been told that I need helper springs to stiffen the rear suspension to handle the extra load.
Is anyone knowledgeable about the towing capacity?
If not, is there anything that can be done to allow it to tow that much. Maybe a stronger THM350/400 and/or a 330/350 engine? What is the approximate cost/difficulty of doing a swap like that? I'm not too concerned about the fit, as I've read that all three transmissions are pretty similar, and 442.com says that almost everything is interchangable between a 307 and a 350. The car has a huge engine compartment and my research says that during the late 70s it had 350ci and 403ci engines, so fitting one in shouldn't be a problem.
Thanks
PostPosted: Sat Jul 08, 2006 3:33 pm
Hi,
Find out what the boat/ trailer weigh. If it's a fiberglass boat (this is a shot in the dark) I'd say anywhere from 2800 - 4000 lbs. I used to work on boats and I know a 19' bow rider weighs around 3000. Yours, being a cabin cruiser probably weighs more though, so take my guess on the weight with a grain of salt.
Not sure what your car is rated to tow, but if you're towing anything at all it's a good idea to have an external transmission oil cooler, and a transmission oil temp gauge. Even more importantly you need to make sure your brakes are sufficient (trailer brakes also if necessary.)
For proper handling, make sure the boat is properly positioned on the trailer. The tongue weight should be 5 - 7% of the total weight of the boat/trailer. (i.e. if the boat / trailer weigh 3000 lbs, you should have 150 - 210 lbs on the trailer hitch.) You can adjust the tongue weight by moving the boat forward or backward on the trailer. (you will also have to move the bow stop / winch, possibly other things too) Too much tongue weight and your car's ass end will sink, causing possible steering and braking problems, too little tongue weight and your trailer will tend to "fish tail" especially at highway speeds.
Just some general trailering tips I've picked up over the years, you should definitely find out the weight of the boat / trailer and what your car's towing capacity is first.
PostPosted: Sat Jul 08, 2006 3:51 pm
Well, I've got the shop manual, time to consult it.
PostPosted: Sat Jul 08, 2006 4:44 pm
The maximum towing capacity is 1199 lbs.
However, I don't know if that is in reference to the transmission and engine, or in reference to the rear suspension and the current hitch, which is a very light-duty setup. As far as I can tell, it's just a L shaped metal bar attached to the frame in the same place as the bumper.
Would an aftermarket heavy-duty hitch increase my capacity, or is 1199 lbs the most that a 307 with THM-200-4R handle?
PostPosted: Sat Jul 08, 2006 6:55 pm
Hi nalc, hello everyione,
........ I have a '89 nineteen-foot Oldsmobile Custom Cruiser boat ........
I did not know Olds made boats.
........ The maximum towing capacity is 1199 lbs ........
That's what the vehicle was designed to tow safely using the correct hitch for that application. Your empty trailer weighs that, easily.
........ I don't know if that is in reference to the transmission and engine, or in reference to the rear suspension ........
No, and no.
........ Would an aftermarket heavy-duty hitch increase my capacity, or is 1199 lbs the most that a 307 with THM-200-4R handle?
No, and no.
If you checked the specs for the same platform with a 454 or455, the number would be the same.
I suggest, you find out exactly what the boat/trailer combo weighs and get a Pickup or light truck with the appropriate GVW rating. Then follow 73Delta88s advice.
PostPosted: Sat Jul 08, 2006 10:08 pm
How did Oldsmobile arrive at that number?
I would imagine that it's a combination of engine torque, transmission strength, rear suspension stiffness, frame strength, and hitch strength. How would improving several of these aspects not improve the towing capacity?
Not disagreeing, I just don't understand.
What's a good light truck that has serious towing capacity? The Reken+trailer weighs no more than 6,000 pounds. Will a Bravada/S10 Blazer be able to handle that kind of weight, or do I need one of the big 1500 trucks with 4wd and a V8?
PostPosted: Sun Jul 09, 2006 2:14 am
Hi nalc, all,
How did Oldsmobile arrive at that number? ........
Good question to ask the design/engineering team at one of the surviving auto/truck Mfrs.
........ I would imagine that it's a combination of engine torque, transmission strength, rear suspension stiffness, frame strength, and hitch strength. How would improving several of these aspects not improve the towing capacity?
Engine and trans are less important than the load carrying ability of the entire chassis, including brakes, wheels, and tires.
........ Not disagreeing, I just don't understand ........
Doesn't matter, you have legitimate questions. If my answers are not clear, ask follow ups.
........ What's a good light truck that has serious towing capacity? ........
Look for the GVW tag on the driver door. For reference you can look in the same place on your Olds.
Actual weight of both the truck and the trailer should be less than the number on that tag. If those numbers are right the truck will work fine. Other than that, it's your choice.
