It is currently Mon Nov 23, 2026 9:13 pm
 Posted: Thu Jul 20, 2006 11:17 pm |
nalc wrote: What I mean is that a relay that makes it so that if the car is not running, the lights won't be able to turn on. Apparantly it's a relay between the light switch and the line to the radio that is only on when the key is in 'On' or 'Acc'.
so you want the power to the lights to be switched. This would not be accomplished via relay, but by a switch, or by a switched power wire. You should have a buzzer that tells you your lights are on, maybe get that operational?
 Posted: Fri Jul 21, 2006 9:37 am |
I saw a long time ago in a JC Whitney catalogue, an automatic lights module. It had the wiring harnesses already for each different manufacturer and model. You just had to stick the light sensor up on your dash somewhere, and plug it in. It would turn the lights on at dusk, and turn them off in the day time.
As I remember, it was only 30 bucks or something. Maybe checkinto something like that? Easy swap, and it would solve the problem!
nalc
 Posted: Fri Jul 21, 2006 9:45 pm |
andrewk wrote: nalc wrote: What I mean is that a relay that makes it so that if the car is not running, the lights won't be able to turn on. Apparantly it's a relay between the light switch and the line to the radio that is only on when the key is in 'On' or 'Acc'. so you want the power to the lights to be switched. This would not be accomplished via relay, but by a switch, or by a switched power wire. You should have a buzzer that tells you your lights are on, maybe get that operational? Andrew
Wouldn't a relay that allowed power to the lights only when the key was in the ignition work?
The automatic thing sounds intriging, but I don't like the idea that I can't decide whether or not I want the lights on. There are situations where I would want the lights on during the day or off during the night.
 Posted: Sat Jul 22, 2006 7:16 am |
nalc wrote: andrewk wrote: nalc wrote: What I mean is that a relay that makes it so that if the car is not running, the lights won't be able to turn on. Apparantly it's a relay between the light switch and the line to the radio that is only on when the key is in 'On' or 'Acc'. so you want the power to the lights to be switched. This would not be accomplished via relay, but by a switch, or by a switched power wire. You should have a buzzer that tells you your lights are on, maybe get that operational? Andrew Wouldn't a relay that allowed power to the lights only when the key was in the ignition work?
definition of a relay:
A magnetic switch which uses a small amount of current, in the control circuit, to operate a component needing a larger amount of current in the operating circuit. A remote switch.
www.partselect.com/range-stove-oven+Glossary+repair.htm
So yes, and in fact this would be the only way to ensure that there wasnt too much current going through the ignition wiring. So I retract my previous statement... dont know what I was thinking.
 Posted: Sat Jul 22, 2006 7:23 pm |
Hi andrewk, hello everyone,
andrewk wrote: ........ You should have a buzzer that tells you your lights are on, maybe get that operational? ........ That's why the factory put it there. Unless the problem driver has profound or severe hearing loss, it would be the simplest and most practical solution. nalc wrote: ........ Wouldn't a relay that allowed power to the lights only when the key was in the ignition work? Power to control a headliight relay could be hooked to the "key in ignition" warning device, but I don't see that circuit handling the amperage. Your FSM will tell you the existing wire sizes, and you can go from there. andrewk wrote: ........ A remote switch ........ That is actuated by a switch on a separate "control" circuit. For instance, the starter relay is activated by the "start" position of the ignition switch, if the "neutral safety" switch is closed. That circuit does not carry the 200+ amps used by the starter to turn the flywheel. andrewk wrote: ........ So yes, and in fact this would be the only way to ensure that there wasnt too much current going through the ignition wiring ........ It would eliminate any doubt about the ability of the "control" switch to handle the high amperage, by using it in the "low amp" circuit instead. andrewk wrote: ........ So I retract my previous statement ........
It was accurate, just not complete.
Nalc: I don't think the ignition switch will handle the load, so I would use a headlight relay. For more go here.
Now, are you sure the problem is the driver, not the car?
Regards, Norm.
 Posted: Wed Jul 26, 2006 8:57 am |
I wouldnt try driving your headlights off the "accessory" line. But, with a haynes manual or something of the like, you will be able to locate all the wires nessesary for your install.
If you are serious about the relay, it can be done. If you arent experienced with wiring and relays, consider getting a hand from someone who is, you can make a real mess out of a vehicle's wiring system if things go wrong.
